Results 1 to 2 of 2
    Jan 2003
    Default Dreambox 500S with PLi Helenite recording problem
    Hi
    I am having major freezing/pixels problem when recording, ie every few seconds, u get freezing/pixels problem. I had tried different settings but none could really fix the problem.
    My PC is Pentium 4 - 3.0 GHz (2Gig Ram). The dreambox is connected thru wire to the router. I know the problem is not the connection as I can stream the same connection using xbox to watch movie with any problem.
    What are the optiomal settings should I use in the dreambox with PLi Helenite image? Any suggestions?
    alanpaladka
    Even I had same problem with my DM having Gemini 4.0 image. Till now, I haven't found any solution for it.
