Results 1 to 14 of 14
    Mar 2007
    Question Insat 2e / 4a Possible In Same Dish
    Hello Friends,
    how to watch channels from insat 2E & 4A in same dish,because both have same location at 83 E
    thanks in advance
    Africa-Kenya-Nbi
    Quote Originally Posted by THE DON View Post
    Hello Friends,
    thanks in advance
    think you need a combined c,ku lnb
    to do the same location on c band and ku.
    Mar 2007
    DEAR COGIL,
    I WANTED KNOW ABOUT C BAND CHANNELS ON INSAT4A,WHEATER WE CAN WATCH 2E/3B/4A C BAND CHANNELLS TOGETHER, PLS ADVISE
    THANKS IN ADVANCE
    Africa-Kenya-Nbi
    DEAR COGIL,
    THANKS IN ADVANCE
    yes its possible, same satellite, same position, and the transponders receivable at your location.
    alanpaladka
    @THE DON
    All channels of Insat 4A are placed at Horizontal polarization whereas Insat 2E channels are placed at Vertical Polarization. So you should have Dual Lnb Feedhorn and 2 Lnbs inorder to receive them all.
    Quote Originally Posted by alanpaladka View Post
    @THE DON
    Thats very good info. Im in the middle east and have a 8 ft dish. I hope if i add another lnb or get a dual feed one , i will be able to get insat 4a
    Thanx
    alanpaladka
    Yes ofcourse. Buy a dual Lnb C band Feedhorn and try.
    Mar 2007
    @THE DON
    WHAT ABOUT IF U HAVE LNBF,WHERE U CAN GET BOTH FREQUENCIES
    WILL IT WORKS,
    Africa-Kenya-Nbi
    WILL IT WORKS,
    should work if has H and V (dual polarity)
    Mar 2007
    DEAR Friends,
    MY LOCATION IS DUBAI, I AM GETTING INSAT 2E , NOW I WANT GET INSAT 4A, SO I CHANGED LNB F FOR BOTH POLARITY, BUT I DID NOT GET ANY CHANNELS, I WANT KNOW WHEATER INSAT 4A CHANNELS available IN DUBAI, PLS SUGGEST ME HOW TO TUNE DISH,
    UR EARLIEST REPLY APPRECIATED.
    THANKS IN ADVANCE
    Aug 2004
    MIddle East
    DEAR Friends,
    THANKS IN ADVANCE
    Mate, All channels from ( except a few are in regional beam ) Insat 2E / 4A are available in Dubai... Insat 4A channels have better signal strength than Insat 2E channels... All what you want to do is make sure that your LNB is a Dual polarity supporting one Same dish u can use...... Check the LNB inside, there you can see two slight polls set both vertically and horizontally if thats a dual Pol. LNB...... I believe the LNB you are using in not dual polarity supported one / you fixed that in wrong direction.
    Love to explore new informations. Share and take.
    Mar 2007
    What's The Use Of Teflon Insert In Lnb, Should We Use It For Inast 2 & Also There Is Plastic Cover, Which Should Be Removed Or Covered
    Thanks
    Dec 2007
    Kerala
    Hello Friends,
    thanks in advance
    Yes its Possible, For the same You need Separate LNB's
    I am getting the same on My 6 Feet Dish. I mean Asianet & Soorya on Same Dish.
    Mar 2007
    Thanks
    @The DON
    - There are about 11 TPs of INSAT-2E , all Verticals,
    ("wide beam" covering mid-east ) which you should easily
    receive on a 6-ft.)
    - All TPs of INSAT-4A (All Horizontals ) easily cover mid-east.
    - Eventhough 2 different Sats, there's no question of "clashing"
    bcos ALL 4A TPs are Horizontal and ALL 2E TPs are Vertical.
    - Pls get yourself a Dual-Polarity voltage switching LNBF.
    - "Teflon" is ONLY used to boost Circular-polarization TPs.
    ( ex. some russian Sats ). Do NOT use for V/H polarizations.
    - Plastic cover only for protection purposes and does not play any
    electrical/technical roles.
    Good luck.
    Kamaldeen.
