    Default Cable Pin Connection For Starsat Receiver
    I Have Tried To Upgrade Starsat 200 Ci Plus Receiver By Using Rs-232 Cable .but Can Not Detect I Used Connection Is As Below
    9 Pin Type Cable Both Female Type
    To Receiver To Pc
    Pin No 5 5
    Pin No 2 2
    Pin No 3 2
    But Not Detect. I Used Echostar Receiver , It Is Working
    So Please Give Info About How To Make Correct Cable For Echostar 200 Ci Plus Receiver
    Thanks For Your Expertise
    CAN I GET NEW SOFTWARE FOR ECHOSTAR 300 IR RECEIVER FOR UPGRADE
    21.95° N 97.06° E
    Quote Originally Posted by surendrak View Post
    To Receiver To Pc
    Pin No 5 5
    Pin No 2 2
    Pin No 3 2
    Try with 2-2 , 3-3, 5-5 .
    " 李俊明 Born To Help People "
    Nov 2003
    United Arab Emirates
    my friend YAN NAING for starsat receivers cable should be cross
    2-3
    3-2
    5-5
    my friend surendrak try this method it should work
    Default Actually I did as you replied
    Dear Dodi,
    I did 2--------3, 3----2 and 5-----5. it is working in echostar 3000ir receiver but not in starsat 200 ci plus
    please help.....
    Nov 2003
    Dear Dodi,
    please help.....
    r u sure your computer port is ok?
    if yes then
    put off your receiver
    run SimpleUpload.exe file
    put on your receiver
    it should work
    21.95° N 97.06° E
    Quote Originally Posted by dodi View Post
    2-3
    3-2
    5-5
    Thx. bro. dodi , that's my mistake.
    Regards.
    Nov 2003
    Regards.
    Its ok, my friend, YAN NAING
