Results 1 to 9 of 9
Thread: DM Box 500 Help
    Oct 2007
    Angry DM Box 500 Help
    I'm having a problem thats getting on my nurves.
    whenever i delete channels from my channel list it comes back when i switch OFF/ON the Power from the main supply!
    Kindly help !
    THAILAND
    Quote Originally Posted by Mil1er31 View Post
    Kindly help !
    may i put this post back in the front has im sure the rdi forum can solve
    mil1er31 problem.
    i also have a OFF/ON power problem with the parental lock on my dreambox500
    i can parental lock a channel no problem but when i switch off and then on again
    the dreambox wont save the channel lock.
    i have done a search on rdi without any luck
    once again kindly help
    JOE SOAP
    Mar 2003
    98.98 East 18.56 north
    Quote Originally Posted by JOESOAP View Post
    mil1er31 problem.
    simple to solve this Problem
    you Setup the channels on the DB finish you must REBOOT The Dreambox
    so you switch off and on the Main power the Dreambox will start on the last Reboot !
    Daeng
    10FT Dish 169° east-49°east
    THAILAND
    thanks daeng
    JOE SOAP
    Jul 2007
    if you have any problam contect with me .
    You need card sharing Chack This
    http://cardsharing.freetzi.com/
    [email protected]
    Oct 2007
    Default Thanx
    Thanx Alot Daeng
    Jun 2007
    Quote Originally Posted by mkami4pk View Post
    mkami4pk, How many times did I try to contact you via that email ? You never reply.
    Just don't lie.
    THAILAND
    Quote Originally Posted by Daeng View Post
    Daeng ...your solution only works for a while ! After several days and a few reboots. original deleted info ALWAYS returns . In my case its the transponder list. Remove all the unecessary transponders reboot and they are indeed gone. Later you will find them back again It drives you crazy. The quality of the memory chip is just too poor or too cheap on the dreambox to hold the info.
    Mar 2003
    also so no problem solve this
    use Flashwizard and safe your image (Backup) the Box its working fine
    Daeng
