Results 1 to 15 of 15
    Jun 2007
    Default Friends I tryied for ABS1 south beam and ST1 K2 beam but failed to get please Help?
    HI Friends,
    Friends I tryied for ABS1 south beam and ST1 K2 beam but failed to get on my 90 CM MCBS ku band antenna,
    I was able to receive C band signal from ST1 50%,
    But received only 10% signal from abs C band....
    Pls guide me how to receive ST1 or ABs1 on my 90 cm Antenna,,
    Please guide me regarding LNB tilt/screw
    if possible pls send me some LNB screw snaps...
    Banned Member Expert
    Apr 2005
    Coast of Ionian Sea
    No GUTS!No GLORY!
    HI Friends,
    hmm! again and again u r asking the same question......just do one thing...call any one of technician..and he'll do everything...and njoy the birds!
    Apr 2005
    Coast of Ionian Sea
    yeah... call a damn good technician and let him install everything..... and put a motor on your dish so that when you want to watch another satellite channel you will not again and again adjust your dish manually with your glass hammer and spanner......
    No GUTS!No GLORY!
    Jun 2007
    FRIENDS,
    I AM SORRY FOR THAT, THE THING IS IN BANGALORE NOBODY IS READY TO TUNE THESE SATS, 2ND THING ALREADY I HAVE TUNED TO SOMANY SATS ABS1 AND ST1 c BAND i GOT BUT WAS NOT ABLE TO RECEIVE KU BEAM,....
    WHENEVER i ENTER ABS FREQUENCY IN MY RECEIVER THERE IS
    12579 H 22000
    SIGNAL LEVEL ==0
    SIGNAL QUALITY==0
    SO MAY BE MY RECEIVER IS UNABLE TO UNDERSTAND THIS FREQUENCY...
    FRIENDS,
    12579 H 22000
    SIGNAL LEVEL ==0
    SIGNAL QUALITY==0
    ha, may b the problem is ur's box....cozed ' ur box should show anything in "signal quality"...after connected the lnb..if its "0" even the lnb connected....change ur box and try again!
    alanpaladka
    If "Signal Level" indicator is showing 0 then it clearly means that your receiver lost the connection with LNB. It can also happen due to lnb and wire malfunctioning.
    21.95° N 97.06° E
    And don't forget to consider one thing that u need to take a look these Ku Sat's footprint.
    Regards.
    " 李俊明 Born To Help People "
    Jun 2007
    but how come if I change the frequency without changing dish or lnb position signal level starts coming is this my Box(receiver problem pls see my dish and LNB screw for ABS1
    absolutely , the skew of ur lnb is totally wrong for this bird....just rotate it upto 45 degree more up or down.....for simple example...the wire prob of ur lnb shows as 3'o clock....now rotate it as 12'o clock or 6 'o clock side...and then u can get this bird easily but only southern feed!
    Jun 2007
    thanks George I will try hundting for this Bird again this week and Let u know I will rotate my LNB to 6 oc clock or 12 o clock as u said...
    George what will be the screw for ST1 K2 beam....
    rotate the lnb as 2'o clock
    Jun 2007
    ok George.
    Apr 2007
    Thats's a Great way of Putting it Mr. George! Impressed!
    Quote Originally Posted by Mangalore View Post
    thank u and its a simple way to explain.........
