Results 1 to 15 of 29
    alanpaladka
    Default Gbox help on Dailup
    Dear Friend,
    I'm having DM 500-s and 128kbps dialup internet. I can watch channels on CCcam protocol without any problems. But now I'm really stuck on Gbox. After reading many tutorials, I learned about how to create D line.
    My ISP is giving me a static IP which doesn't changes at all. That IP is shared among many users. I can't ping my box/computer using that IP.
    So, can I use Gbox sharing? I have created dyndns account. But I can't ping my computer using that. So does it will create any problems?
    Your help would be greatly appreciated.
    Thanks
    Jul 2006
    Saudi Arabia
    as far as speed is concerned, dear 56k is the max. there is no modem with 128k speed.may b ur pc show that speed but in reality it is 56k.
    to me u have to have specific ip for u. if u r using router for sharing the net then u have to DEMILITIRIZE (DMZ) ur ip.after DMZ, ur pc's IP will virtually connected to the statis IP assigned to u.
    if there is some other solution, it will be informative for me too.
    Dreambox Dm 500
    Nilesat,PanAm sat 7/10,Paksat 1,Arabsat,Hotbird
    alanpaladka
    No. I'm having CDMA wireless dialup connection. Actually, my internet speed is 144kbps. But practically I receive only 128kbps.
    Anyways, I don't have any router. While I watch any card shared channel, I have to keep my computer ON. I have shared my PC internet to dreambox. IP is assigned by ISP itself. I can't change it either. So is it possible to use Gbox in this case?
    pakistan
    for gbox dsl necessary.on dial up u can watch newcamd and dcw sharing and other porotocols very easily.
    alanpaladka
    Thanks thegreat4u2 for your opinion. Even CCcam works fine with my connection.
    So I don't have any chance of using gbox?
    pakistan
    as far as i know its very difficult with dialup lots of freezing with dial up.
    dialup=gbox=freezing
    wait for experts comments.
    that is not actually your native dialup. that is already considered as wireless broadband connection.
    do an ipconfig /all from command prompt and take note of your IP. then from the ip testing websites out there (google for it) verify that you do have that same IP number. you CANNOT ping your own IP from the same box/machine you are using. give that IP to somebody else and let them ping it from there. also make sure that your firewall does not ignore the ping ICMP querries being made.
    i really doubt that you cannot make it work on that kind of setup. you can make it work, all you need is to forward everything to your pc, then make sure that your pc forwards all the querries to your dreambox.
    Jul 2006
    Saudi Arabia
    onething is sure that dialup does not mean freezing. i have 33k dialup but everything is fine. main thing is quality of net.cdma is broadband not dialup but can u find out the ip assigned to u.if so then u can use it.if it is statis the best otherwise u can use ip-date client for dynamic ip.
    Dreambox Dm 500
    alanpaladka
    Dear Experts,
    I'm attaching a screenshot of IPCONFIG window. Please have a look on it.
    Whenever I check my IP using external websites like cmyip.com, I get IP as 218.248.68.169. It is same from last 4 months. It's shared among all subscribers of my ISP.
    Jul 2006
    Saudi Arabia
    u cannot use as ur own ip is 10.2.0.37 but the ip shown on site is that of ur provider.to me u r not able to get connected to gbox server.
    Dreambox Dm 500
    Nov 2006
    Soo what would be the answer tufail....?
    Jul 2006
    Saudi Arabia
    answer is basically he cannot use gbox.
    as i am IT professional, i give a bit detail. his provider has some broadband or high speed net. the provider has made a LAN himself and given IP starting with 10.2.0.xxx. in this system,only if system admin open one ip frm the LAN to the main then only that ip has facility.this is special function.normally it is not provided.
    BOTTOM LINE is that alanpaladka has no solution for him.
    Dreambox Dm 500
    alanpaladka
    Thanks tufail for the verdict.
    Right now, I can view channels shared via CCcam. Which other protocols I can use with my connection? Please suggest me.
    Aug 2007
    @alanpaladka,
    If u dont have a router then what device do u use to access internet.
    Also type this command so that we can know how u connect to internet.
    tracert yahoo.com
    the 10x range is an INTERNAL ip provided by your ISP. your ISP is using a single proxy IP then subsequently routes the traffic to your local IP. VERY BAD ISP. the problem lies on your ISP proxy, it does not forward the gbox packets to your local IP. call them up and negotiate for a REAL IP from them, or at least explain your side that you need for them to open up some ports and forward it to your local IP.
    the easiest maybe is to change ISP.
