Results 1 to 6 of 6
    Jun 2007
    Default Friends PLS HELP ME in receiving ST1(K2) and ABS1(South Beam) Ku Band
    I am in Bangalore I am Unable to trap St1 K2 Beam and ABS1(South Beam) Ku Band
    Pls Guide me how Can I receive these 2 satellites I tryied with my 60 CM Dishtv Antenna
    and my 90 CM Ku band Antenna but I failed to receive
    Hindustan
    Thumbs up
    1. Use a (Rs 25/-) magnetic compass to see the exact degrees for 75 E
    2. and a protractor (Rs 2/- )with a thread at center for Az/Inclination measurement
    I got every bird with this simple home make instruments
    BOL
    Technology Makes You Live
    Jun 2007
    Can Anybody share me some Photo showing LNB tilt for ABS1 and ST1
    alanpaladka
    I have not tried to receive ST1 KU band. But ABS1 south Beam is very powerful. You can receive it very easily.
    Jun 2007
    Today Again I tryied for ABS1 C band and Ku band But failed to receive on my C+KU combine 90 cm antenna....
    Then Again I tryied for ST1 I was able to receive ST1 C band on my 90 cm antenna...
    Union territory
    hello bangalore friend,
    as a beginner dont waste ur time with small dish, go for minimum 6ft and try all the sats, u will get it,
    btw, st1 k1 beam is easily receivable in 60cm ant, not K2-beam, that is not for india, abs1ku-southbeam u can get it in 60cms,
    bye
