    Default Satellite signal Boost inline high amplifier
    hello,
    Can any one please tell where can i find the Line amplifier for satellite in pakistan,
    http://i21.ebayimg.com/05/i/08/b7/fb/c7_2.JPG
    kindly give me the address from where i can order.
    regards
    swat2
    suleyman
    canine consultant Expert
    Could you tell us, why you think you need a "line amp"
    really the use of Line amps died with the advent of "digital" transmissions, unless you have an extraodinary long cable run, in excess on a couple of hundred meters, one is not needed, and even if your cable run is that long simply substituting PG 11, instead of RG6, will solve the problem,
    regards from OZ bassett
    Default line amplifier
    hello,
    yes i have a Long cable more then 100 ft.I had an amplifier earlier but that got damaged while shilfting.now i am in need of one as to boost the signals
    can u give address of any shop in pakistan that sells one.
    ps* (the old amplifer worked great for me on my digital receivers (free to air + Dish tv one)
    shall be waiting for your reply,
    regards
    swat2
    suleyman
    Quote Originally Posted by swat2 View Post
    hello,
    regards
    swat2
    A 100ft [33 meters] run is nothing, and providing your dish is of adiquate size, you should not require a line amp. Line amp's will not boost the signal, only maintain what is already there.
    Sorry can't help you with a retail outlet, I,m not in your part of the world, You see them sometimes on E-bay.
    Africa-Kenya-Nbi
    33meters is still just a normal length and doesn't require any booster
    or line amps.
    My example is; have run 100m from a storeyed building top to ground floor, using rg6. the signal quality dropped from 78 to 65 and that is still very good.
    Only make sure your dish is perfect and well tuned, then ignore the amp.
    if the drop is higher then go for better cable quality, though expensive serves the real purpose.
