Results 1 to 14 of 14
    Sri Lanka
    Default hELP --How to find BOX key
    hello dear friends
    i HAve Dialoge tV packege(intelsat 12-45E) COSHIP CDVB 5110D receiver + ****** original card,
    both are married together;
    can some one give me a methode to find the box key of this unit or any relevent soft ware.
    i have CAS 2 interface,
    i need this becoz i have a dream box7020 and i need to put that card on DB to watch Dialogue tv
    any help highly appriciate,
    thanks
    Krish
    Mar 2007
    Quote Originally Posted by krish View Post
    hello dear friends
    thanks
    Krish
    The box key will be in the secret menu part
    once you get the box key you then have to convert hex serial
    do a google search
    Mar 2003
    98.98 East 18.56 north
    hello dear friends
    thanks
    Krish
    Irdet"2 using Boxkey ?
    Dialog TV using caid: 0631 and V5 cards i know you dont need Boxkey
    so put your Card in to the Dreambox and use CCcam
    Daeng
    10FT Dish 169° east-49°east
    Quote Originally Posted by Daeng View Post
    i also tried with another some irdet* boxes , likes nokia dvb2000 with irdet*cam and some higher version irdet* empeded boxes....but no luck! so, it may need some box keys.......
    MVDIG Teacher
    Maldives
    DialogTv no need box key
    They using very latest encorder for some old box Tuner not supported
    You can check dreambox and latest other ****** box.....
    Sri Lanka
    Quote Originally Posted by junaid View Post
    dera sir Junaid,
    so what can i do,?my receiver is coship and Dialog original card.pls tell me how to work this card in DM7020?i need to watch these packege on my DB7020..
    thanks all
    krish
    Sri Lanka
    i installed gemini 4..incccam 2.0 i found several files..pls let me know where do i put these files in DM7020.
    pls help me to put this CAID 301 to watch Dialog tv by DM7020
    thanks all
    krish
    Aug 2008
    Quote Originally Posted by PhuketSatellite View Post
    do a google search
    What do u mean by the secret menu? I'm looking for the BOXKEY for zenega receiver working with dishtv. I want to use the dishtv card with DB. Reading at various forums/posts , it seems like the BoXKEY needs to be there in the cccam.cfg file to make the card work on Dreambox.
    Any inputs will be highly appreciated.
    Regards,
    Rajat
    If Dialog tv is using a V5, that means its an Epilson V5.1 Card, which cannot not be used in DM, the only way you can use it is with Ir**to Cam in any other STB, which has CI Slot
    but you have to upgrade the Cam from V1.06 to V1.12, which i have done, i am using Pehla
    Card which is V5 Epilson, but i have upgraded my Ir**to cam and now its updating the subscription everymonth & also has speed up my STB when i switch channels.
    Dec 2009
    Hi Everyone.
    Could someone please tell me if it is possible to extract the BOXKEY from an ...... 2 ZETA card using a Dreambox 500S and jtag cable?
    The smartcard and original decoder are married to each other.
    I have tried converting the serial to HEX but that didn't help unscramble the service.
    Thanks
    Dec 2007
    INDIA
    Cool Ir det0
    need Cam key and Cam key data for descrambling the picture. Box key alone didn't give you any picture.
    Dec 2009
    Quote Originally Posted by anishpsla View Post
    Thanks for your reply. I have what I believe to be the correct CAMKEY and CAMDATA values for my ...... 2 ZETA card. The problem I have is that the smartcard is married to the DSTV provided decoder so when I take that same smartcard and put it in my dreambox (DM500S), I get a green (i) but no picture or sound. I believe I need to extract the boxkey from the smartcard but haven't found anyone helpful/knowledgeable enough to confirm or deny that fact.
    Has anyone here, post 2008, got a newer version married DSTV card to work in their dreambox?
    Thanks
    R-D-I SPONSOR Mentor
    Thailand
    Default re
    Quote Originally Posted by jacksback View Post
    Thanks
    hows south africa today - lol
    Silly question maybe but why dont you just use your original decoder since your in south africa why would you want to put it in a dreambox decoder ?
    Im sure the original decoder from ZA is much better
    Dec 2009
    South Africa is good thanks.
    And to answer your question, NO!, the DSTV decoders are sluggish and buggy as hell. My Dreambox DM500s and IceCrypt HD PVR are miles faster and better in every way.
    Back to my question, does anyone here know how to extract the boxkey from the smartcard using a Dreambox and Jtag cable?
    OR can someone give me other options to use the married card in a Linux based decoder?
    Thanks
