Results 1 to 6 of 6
    abazsg
    Question need Upgrade 1.1.1.exe plz help
    hi
    today i brought neosat sx1600 plus
    i tried to upgrade with Upgrade 1.0.7.exe but nothing happen
    i check it loader info it was 1.1.1
    plz help how to upgarde recever ...
    thanks....
    Quote Originally Posted by abazsg View Post
    hi
    thanks....
    here its the latest software , loader and upgrade tool for ur box and first download the loader 1.0.7-6 (don't forget to select the "download loader" option in tool) and then down load the main software!
    abazsg
    Default hi
    thanks for sharing
    the program upgrade 1.07 does not work when i do like you said it say connecting.....
    i restart the recevr but noting happen ..no updating..
    my loader v is 1.1.1
    not 1.0.7
    i need connecting utility program...i mean new version of upgrade software..
    thanks for sharing
    not 1.0.7
    so , that i told....u should upgrade the boot loader first.....
    abazsg
    Default hi
    thanks dear georgekamal problum is solved ..
    my recever is communicating with "upgrade 07-26-2007 boot loader".
    and software is of extension abs.. not bin..
    thanks a lot..
    one thing more if u have boot loader 1.0.7 neosat sx 1600+ In abs format then send other vise its ok now..
    thank you very much
    You are the Boss..
    thanks a lot..
    thank you very much
    You are the Boss..
    thankx for feed back....and i cannot catch u! i mean...ur box is now ok with new software.....then why did u worry about again boot loader? in future , u don't need upgrade it again...after u got new software...just upgrade it, without worry about boot!
