Results 1 to 15 of 26
    May 2007
    Down the road
    Default Need help using VLC with DM500S
    Got the Dreambox running pretty well.I'd like to be able to learn how to set things up so I can view shows in the PC using VLC.Computer already hooked up to Dreambox and using DBCC and DB edit.All working fine.Need to learn how to use VLC.
    Aug 2007
    If you are using Gemni image then open the web interface for your dreambox. There i saw an option on the top i think it said View Current Strem. click it. It should start VLC and u will be able to view the current channel in PC.
    to open the webinterface of your dreambox type as follows.
    Open Internet Explorere and then type this address for your dreambox.
    e.g. if your dreambox ip is 192.168.0.2 then type this
    http://192.168.0.2
    login
    Jul 2006
    thailand
    Quote Originally Posted by mellow View Post
    it works better if you use firefox
    Jun 2006
    Thailand
    don't forget 2 search the forum.
    it's all there in post by emco83 and felicianf
    May 2007
    Down the road
    Using NABILOSAT image,has same option,but said installer corrupted .Guess I have to re-install VLC.Thanks.
    Mar 2007
    Default re
    make sure u have also downloaded VLC onto your PC for it to work
    download from www.videolan.org
    Make sure u choose FULL INSTALLATION
    Also download Java for your PC
    You should then have no problems
    May 2007
    Down the road
    Re-installed VLC,Java's been in the PC for a long time.Still doesn't work.It does work with Dreaview,but the picture is too dark.
    Jun 2005
    Australia
    I had more luck with Dreamstream.
    Do a search for that I think you'll like it.
    May 2007
    Down the road
    Quote Originally Posted by norman23 View Post
    you are a weird guy...weirdo...haha
    your obviously an expert on weird,but I'm not here to learn about that.You know anything about the information I'm looking for?If so,please put your writing skills to work on that.Thank you.
    Jun 2005
    Australia
    ouch! stop poking me in the eye! lol
    No seriously mellow, download Dreamstream and give it a go.
    May 2007
    Down the road
    Quote Originally Posted by weirdo View Post
    Couldn't get it to work for me,still using Dreamview,thanks anyways.
    alanpaladka
    I'm still not able to use VLC. Picture is coming, but too much freezing. I have also tried DreamStream. But same result.
    Quote Originally Posted by alanpaladka View Post
    try dreamview,,and also it is possible to tweek ur lan settimgs on ur pc by about 20% over standard setup,,that made a lot of difference for my pc's
    cheers,,,dave
    alanpaladka
    Thanks for the suggestion.
    I tried DreamView. But picture freezes too much
    Aug 2007
    Guys Whenever i try to use the vlc the dresm box get stuck and i have to disconnect it from the main. also tried this dreamstream but its in german language how to put it to english, although i tried it and still the box get stuck don't know why?
