Results 1 to 3 of 3
    Mar 2007
    Default Dreambox Expert help me
    i have Linksys WAG200G Router
    how i connect linksys with dremabox 500s can any 1 help me
    Jun 2005
    Australia
    Quote Originally Posted by skotri View Post
    I can only speak for Enigma image but this might help you out.
    Go to Menu > Setup > Expert Setup > Communication
    Set it for DHCP and select Ok or Save at the bottom.
    Your router will assign an Ip address to your box automaticly.
    Quote Originally Posted by weirdo View Post
    that is, if DHCP is enabled on the router. enable it, if you choose no, config your dreambox to have 192.168.1.1 as the default for linksys WAG200G.
    this is already offtopic but may concern you very badly. also, try to patch the firmware of your wag router since it responds with the username and password for the browser setup menu (the one you use to access the router to configure it) when flooded with UDP packets on port 916.
    just a word of advice.
