    Aug 2007
    Question Dream box dm- 7000s NOT booting pls help me
    I have one dream box dm 7000 s .i yesterday i make default setting of this stb.
    now he is not booting and no display on tv.
    what is the problem.
    please guide me how i make this start again.
    help me...
    if you have installed a hard disk on it, try removing that and booting without the hard disk. or if you can telnet to the box, make sure that boot from flash is enabled or delete recordings.epl from hdd/movie/ since it might be corrupted.
    if that does not boot the device, turn off the device. now hold the lower button (or all the buttons) on the front panel, power up, keep on pressing until you see the logo for 10 seconds (or the orange light comes on since you cannot see anything on the tv), release and hold the button again for a hard reset of your box. all this does is a cold boot for your dreambox.
    if all else fails, JTAG with cas2 or something else.
    if you can specify which procedure you were doing prior to this failure, that would help too. but i suspect you were flashing something to the box.
    21.95° N 97.06° E
    Plus he can re flash with original image I think.
    Thanks.
    " 李俊明 Born To Help People "
    Aug 2007
    If your DM 7000s has a USB slot then using flash wizard put and image on your USB stick and try booting from your usb stick.
    Thanks.
    yes u right...it may solved after reflash the original image via dreamup!
    that's IF he can still access the box. for all we know, the bootloader is corrupted. in which case.... JTAG.
    hi m8,,can u give a brief overview of what jtag is please?
    cheers,,,dave
    Jun 2006
    Thailand
    u can do a search on the forum. yan naing did an excellent topic on this in the sticky's. http://www.rdi-board.com/showthread.php?t=37325
