Results 1 to 11 of 11
    az30094
    Default Cable Satellite STB
    Recently, I was in Bangalore. I found a friend of mine using a set top box, and he was getting digital channels through the cable. I believe the same cable was carrying Analog channels too.
    The set top box has options only to scan for channels and their organization. I did not find any options related to satellite configurations (like LNB settings, Diseq settings etc.).
    I want to know:
    a. Is both Analog and Digital TV is broadcast on the same cable in Bangalore?
    b. Can a satellite receiver be used as a cable stb? If yes, what special settings to pay attention to?
    c. What are the models of cable STBs available in Bangalore and how much they cost.
    I know a lot of RDIers are from Bangalore, and I am expecting a good response.
    Chennai, India
    Quote Originally Posted by az30094 View Post
    I want to know:
    I am not from Bangalore but we are using these kinds of stbs from 2003 in Chennai.
    YES
    NO, but might be possible if you can change the tuner, software etc., which ends as a new stb. Moreover Cable stbs use QAM for modulation. A software change is need for that.
    az30094
    YES
    Thanks lnb15k, you have made a valuable contribution to my knowledge. Now, I should be planning to buy the stb for the cable. I will appreciate if you highlight some of the stbs available in the local market. Are there any stbs with integrated cable modem built in for accessing internet?
    Jul 2006
    I want to know:
    Hi,
    Im from Bangalore & we use Humax cable TV receiver, but now my location is middle east, but my folks are there.
    Models depends on the cable operator & you will get a smart card as well, and soon they will make it conditional access or CAS pay for what you watch.
    The present cost is Rs 5000 & may differ from operator to operator, but first check with your cable operator in your locality.
    On digital you can see (EPG) program guide & better picture quality & sound.
    Not sure if there are any STB for satellite & cable 2 in 1, please check Humax site.
    Chennai, India
    I don't know about Bangalore. But normally there won't be anything like that. Because it will increase the price of the set top box. You need to buy STB from your MSO only and also you cannot use it with any other MSO.
    Out of curiosity I am asking: Why you need to access internet through the STB?
    Jul 2006
    I believe in the US cable STB can be hacked & U even get hacked ready box, also some guys subscribe for minimum & then watch the maximum channels.
    az30094
    Quote Originally Posted by dom06 View Post
    Hi,
    Thanks dom06.
    I have seen the box in action and was impressed with the quality of picture. That is why I was interested. The box that I saw has a CA slot, but there were no channels that required this option, as all the channels were open by default.
    Thanks for the info.
    az30094
    Sometime back, there were talks of high speed internet access through cable. I remember CityCable operator was even advertising it. I was just curious to know if this thing is available at all.
    Chennai, India
    @Az30094
    Thanks. For that I think a cable modem is enough
    MVDIG Teacher
    Maldives
    You can use Dreambox with C Tuner same software and sharing too!
    Jul 2006
    Yes long time back from Siticable (Zee network) with an S & also from Hathway cable operators, a bit more expensive, as they compete with BSNL DSL & also CDMA providers like Airtel & TataIndicom are giving wireless & cheaper than them, but Im not sure about their real prices. Just heard about it, may be a google would help.
