Results 1 to 15 of 16
    Aug 2007
    Default Strong Satellite receiver - srt4652
    Dear Members,
    I have (Strong Satellite receiver) srt4652. It is doing fine. Initially it had the following system info;
    Model: SRT 4652
    S/W Version: 1.54p (August 19, 2006)
    H/W Version: 2.50 (0b:13)
    CH Version: August 16, 2006
    Through Strong website I found Software update for the machine. I downloaded it and followed instruction to update. I ended up getting this;
    Model: SRT 4652
    S/W Version: 1.30 (July 03, 2007)
    H/W Version: 1.11
    Boot version: 2.50(0b:13)
    CH Version: A014
    My receiver seem to be downgraded, though S/W version have a newer date. I can't access some of the features which were there before upgrade.
    Please kindly assist where to get the newest software or my former stb file which I believe is better than the latter.
    Mbalase
    Dar Es Salaam - Tanzania
    Africa-Kenya-Nbi
    you cannot downgrade a hardware with a simple software patch.
    if it ain't broken.... DON'T FIX IT!
    Aug 2007
    Dear Cogil,
    Your link took me to SRT 5390 PVR software, which I think might be incompatible with my receiver. Within the same site there is software for srt 4652. That is the one which brought me the current problem.
    Aug 2007
    Dear Members,
    After working, for almost the whole day on this problem! I'm happy to inform you that I have finally solved the problem using the file below;
    Finding such a file in the web is a little bit tedious.
    SRT4652AU_132p_20060901.stb
    Lets keep on looking for the newest version of the above file.
    Thanks for all who responded to my post.
    Banned Member Expert
    Apr 2005
    Coast of Ionian Sea
    you are actually on the right track when you upgraded your receiver's s/w but there is a minor s/w flaws with this receiver.
    SRT4653, 4655, 4657 s/w's are basically the same w/ 4652 w/regards on s/w patch. in your case, s/w V1.30 (July 03, 2007) actually did not upgrade everything. like i said thats your s/w version "flaws". what you should do is try and find the s/w that will likely to match your receiver and older version of s/w usually works better w/ these newer s/w patch...
    maybe you can still find something useful here: http://www.strong-technologies.com/frmDownloads.aspx.
    No GUTS!No GLORY!
    version name or hardware name is irrelevant in most cases. what's important is that your box is working. the coder can make it appear to any date or revision he likes. but if you are that troubled, then go back to the links posted by Zoren and Cogil and upload the official patch to your receiver. you may lose emulation and end up with an FTA.
    Africa-Kenya-Nbi
    Quote Originally Posted by mbalase View Post
    Dear Cogil,
    sorry but,
    i used the word try
    mine worked on it though.
    Also noticed strong will not accept the wrong software
    right from start, they might differ in some features, but when
    you revert back to old (original) its same as before.
    his problem is the DISPLAY of the software version. wtf is wrong with that? it can display version 0 or even made to state (premanufacturing version) for the world to care as long as the software works! hexedit the file version if you want it to display whatever you want.
    maybe he has that itch to always look at the software version every 5 minutes or so.
    Aug 2007
    I 'm worried my problem was not seen to the bottom of the limpid pond by some members. Later, today I will give detailed explanation to what transpired. And probably this will help our friend to respond prominently if a need be.
    In the same post, I will give more information regarding the receiver as few minutes ago, I received newer version of the file.
    as i have stated in my previous post, the hardware version being displayed by your software is irrelevant. to wit: no software can modify a hardware! to downgrade a hardware means physically replacing it. as has been mentioned by Zoren, it is a minor software flaw in the box itself.
    if your box is working fine and dandy, why bother what version number is displayed by the software?
    but yeah.... go on flashing your box until you find a software that displays the version to your liking.
    Aug 2007
    Downgrade can mean several things. Not necessarily hardware as you keeps on appraising
    canine consultant Expert
    Unfortunately, this is a big problem with software downloads, we hear this time and time again, ***** please supply latest software for ***** and I ask the same question every time,, Why change something that is working perfectly, does what you want it to do, and your conversant with the program's working's . In short, "IF it ain't broke, don't fix it. And for some strange reason people always want the latest, regardless of what it may or may-not do.
    Also people don't seem to release , that there is always a small risk to installing new software, even in a perfect world, things have a habit of
    going arse-up.
    regards from OZ bassett
    Africa-Kenya-Nbi
    learn to appreciate when you are helped,
    it comes in many ways, but such experienced
    members, however rude they know what they
    are telling you is right, they may have tried B4.
    downgraded in what? software and hardware version info? as i mentioned, you can have the software and hardware version info to display to whatever you want. and some of the functions you mentioned must have been disabled to make space on the memory for the emulation to work.
    anyway, we are going around in circles, lol.
    have a nice day.
