Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Question using 2 receivers
    hi,
    wondering if anyone is SUCCESSFULLY using 2 receivers and how?
    i am running from dish to silverbox,,then looped to dreambox,,,silverbox mainly used as dish positioner,,but if power is left on to the silverbox,,it causes a slight pixilation (10-15%) every 7sec or so,,but if the power is off on the silverbox,,no pix problem,but,occasionally the dreambox will loose all snr until i switch it back on,,like it needs it for initial power to the lnb,,and has drained a power reserve in the sivlerbox's capacitors or something,,maybe other members can explain this to me.,,,do i need to split the signal so they are both independant stand alone boxes and not looped?
    any thoughts will be appreciated,,
    cheers,,,dave
    Banned Member Expert
    Apr 2005
    Coast of Ionian Sea
    alot of thread like this query came out before, do a "search" it will lead you to another similar thread...
    that is possible... but not recommended for other receiver's "loop out" w/regards to Hor and Ver out...
    here's one thread you can read How to use two recievers from one diseq?
    No GUTS!No GLORY!
    May 2007
    Down the road
    On the thread,they say using a dual LNB is the safe way to go.I looked at the picture at Amazon.co,it has 2 male coaxial outlets.Is there a reason why using a spliter directly attached to the single LNB outlet wouldn't work?Then running a xtra line to the 2nd receiver,just to change channels while viewing the same Sat.Example:2 receivers on Agila KU,Dream TV 1 receiver HBO,the other Cartoon network.
    21.95° N 97.06° E
    hi,
    cheers,,,dave
    Loop is not good to use for C band , I mean will not work for both polarity.It'll only work for one polarity H or V. But actually u can do it for Dream tv bcoz. most channels r transmitting with Horizonal.I've split my 5 receivers without using any splitter.Just only use with cable in-out , in-out with loop.
    Hope it'll help u anyway.
    " 李俊明 Born To Help People "
    do u have any pixilation problems like i discussed b4?,,do u have all receivers powered on at same time
    21.95° N 97.06° E
    I don't understand well the mean of "Pixilation" . Yes powered all receiver at same time , two X-Sat , Silverbox , Angelbox and Dm (last MDM).They works well for me but as Sir Boknoy said this is not good to use and will affect to ur receivers' tuners.
    Thx.
    Thx.
    pixilation is when the picture has small squares of mixed still image.
    Apr 2005
    Coast of Ionian Sea
    if you intend to use ver and hor at the same time...... don't use "loop out" should not be your first choice. it's unsafe for the receiver... the worst thing it could happen to your receiver or both receivers are, hor and ver voltages canceling one another or w/c receiver will unlikely to withstand the current it can take but both receivers are susceptible to damage. i've seen two receivers both tuners toasted
    No GUTS!No GLORY!
    Jul 2006
    thailand
    Quote Originally Posted by Zoren View Post
    he has been told all this via pm to me and i told him on other furum for the last time IT WILL NOT WORK IF YOU HAVE F1 AND DM ON AT THE SAME TIME you have no reason to have both on it will fuck your box up the f1 box is only a positioner now STOP GOIN ON
    Quote Originally Posted by big pimpin View Post
    hi m8,,yes WE have discussed it all b4,and i thank u again for that,,but hey m8,,it does workbut with slight imperfections,,,and i am always open to input from more that one persons experience.
    and if u have no further input on this subject,,,why comment like that !maybe just listen,,and we BOTH might learn something!,,it seems there ARE other alternatives for this type of setup.
    Jul 2006
    thailand
    the slight imperfections as you say will tell you that it will damage your box you have been warned
    yes bro ,,i have been,and the last thing i want is to damage anything,,but im sure u would be as happy as me if we could find a solution to this.maybe a new invention on the way,,, u never know.
    hope to work together on it m8,,,yes
    Apr 2005
    Coast of Ionian Sea
    it does work.... w/ the use of DiSeqc Sw. http://www.sat-sales.com/proddetail...._diseqc_switch
    but if you are after only one satellite like DreamTV w/c mostly ch. are used only on Hor., receiver "loop out" is ok. much better if dual out lnb on two receivers. like my SS2, connected on one receiver's "loop out" i do'nt have a problem of "imperfection" as you have called it...
    No GUTS!No GLORY!
    thnx m8,,yes,,i am only watching one bird at a time.
    it has been suggested to me that the "timing" cycle of my problem(approx every 7 sec) might be the silverbox looking for, or updating confirmation of keys and other information.,,,any thoughts on this ?
    1. get a dual-out lnb
    2. use power splitter AFTER the lnb
    3. get TWO dish and lnb
    4. reverse your setup if you still insist on using the loop-through, put dreambox first, then your silverbox. make sure you have the maximum signal level you can get.
    5. don't blame us if you fry either one of your tuners.
