Results 1 to 15 of 16
    Default some fittings for ku lnb in to scaller ring-part4
    Chennai, India
    4 new threads for the same subject Why can't you post them in a single thread? All are of the same subject and even most of the photos looks similar. You could have posted them in a single post. It would be better for us. I request mods to move them to a single thread, single post so that we can easily ask doubts if we get any.
    hahaaaaa! first , plz u can try to post all images in a single thread and give the feedback here about ur experience !
    Chennai, India
    Dear Georgekamal, do you mean that you cannot post more than 4 images in the same thread? What is that lnb and for what it is used (offset or prime focus)? You have copied from that other forum give them credits. You used to do it for keys but atleast for this give them credits.
    Jun 2007
    Hi Friends,
    What material is Used to make the LNB fitting for Salar ring is that fitting hand made or its available in Market. Can this fitting be used for KU band Dish Tv LNB.
    Wink
    hi george,,great pictorial information.and i really like the artistic backdrop use of the vents on ur stb!
    cheers mate
    dave
    a picture is worth a thousand words,,,
    dave
    Jul 2006
    George,
    As Dave said a picture worth a 1000 words, forget about the other khali dhaba.
    Coming to topic, scalar ring in Ku band lnb, its the first time I am seeing it & maybe not used in my region. I see they are using plastic fiber bush to hold it.
    Secondly how does scalar ring help in Ku band?
    I assume that if i have an old C band lnb on a dish then I can insert a Ku band lnb, for testing please correct me.
    Then its based on the dish , size & blah....blah.....
    Chennai, India
    Quote Originally Posted by dom06 View Post
    George,
    poda domer. Stop quoting me in a bad manner. Stick to the topic.
    u had rights to ask above question...........
    above ur wordings r proved about ur 4th class mentality.
    Hi Friends,
    this is made from tefflon rod...and its not available in the market...make by lath workshop man guided and designed by me!
    cheers mate
    dave
    thank u! its , noesat1600 plus!
    Nov 2006
    Good Work Geo.. Its a hard material or soft.
    George, how does scalar ring help in Ku band?
    the matter is ....how to fix the ku lnb in to ordinary scaller ring? and whether its ku band or c band....the scaller rings use for prime focus dish and conical feed horn uses for offset dish......
    u cannot get a 100% reflected signal through this way!
    -thankx dom! -regards
    Quote Originally Posted by member91040 View Post
    thankx member..its made from Teflon rod.
