Results 1 to 13 of 13
    Jun 2007
    Default Please Guide me to Receive Thaicom 2/5 Lnb Probe
    Hi Friends,
    I have a 6 feet Prime focus Dish I am receiving Asiasat 3s 70% signal and Yamal 202 also But I am unable to catch Thaicom 2/5 please Guide me how to get Thaicom please share me some Photograph of ur Dish and Lnb Probe for Thaicom.Please Tell me some Strong Tp for Thaicom
    Regards,
    Bangalore
    Chennai, India
    Set the lnb to zero skew. That is the Vertical marking should be perfectly vertical. Also remove the teflon if it is in the mouth of the feed.
    Jun 2007
    Can u show me some photograph telling the 0 Screw and Left/Right screw or some Diagram
    21.95° N 97.06° E
    Dear bro. Bangalore , plz. don't start many threads for ur same target.One will just enough and excellent for the answer.Bcoz. our friends will confuse which one to answer ur many questions.
    Thanks.
    " 李俊明 Born To Help People "
    Chennai, India
    Just make sure the LNB pin (the cable we connect) faces down 90* degrees. That is enough.
    Jun 2007
    If possible Share me a diagram or Snap 90 Degree is 0 probe
    Chennai, India
    Don't mind about the probe which is inside the feed. Just make sure the connection pin where the IF out comes(the cable you connect) faces down.
    Jun 2007
    Ok I got it it means 0 Screw then which side is Now Left/Right screw.
    Jun 2007
    H iFriend ,
    I am attaching Image of Screw please verify I am right or not
    http://img394.imageshack.us/my.php?image=screwds2.jpg
    Shot at 2007-08-07
    Jul 2006
    hi Bangalore,
    It is SKEW & not SCREW
    skew = Turn or place at an angle
    screw = Screws are defined as headed, externally-threaded fasteners.
    screw up = blunder, mis handle (fuck up sorry for that)
    Chennai, India
    H iFriend ,
    Shot at 2007-08-07
    Image was too small and now I have uploaded a picture which was already posted in the forum.
    Check it.
    Jun 2007
    Check it.
    The C/V Gardiner LNB is Skew is what is it Right/Left Not the Dual LNBS
    Chennai, India
    Whether it is a lnb or lnbf what is the problem you face? I don't have that lnb. Some one might help you. If you can post the photo then everyone can help you
