    Jun 2007
    Default How is C+Ku Combine Lnbf its worth spending money for that or not
    How is C+Ku band Lnbf its worth spending money for that or not
    or I should purchase separate separate lnbs and I am getting 17K C+ku for 1800 rs its ok
    Jul 2006
    Bangalore,
    Its your money,
    The difference is around Rs 500.
    It has advantage as well as disadvantage.
    Advantage is you can get birds in one direction in C & Ku frequency only if available & if they are of any use to you.
    Disadvantage is if you are not interested in one of the birds then you dont require a C + Ku lnb.
    So first decide which bird or birds are interesting to you.
    Here in the middle east like me, most people use 3 ku band universal lnb's on a single 90 cm dish to receive 3 birds namely Arabsat, Nilesat & Hotbird just an example of peoples requirements.
    Just curious are you really a Bangalorean or are you from Rajastan settled in Bangalore?
    Jul 2006
    Mr. Bangalore Check this .....
    I am a TV technician from Margao-Goa and a regular reader of your magazine. Satellite reception is my hobby. I currently receive 13 satellites on 4 dishes, using a manual 3-way switch. I receive more than 500 free to air channels.
    On one 8 feet C band dish I receive 6 satellites by fixing 5 dual LNBs and 1 LHC LNB.
    1. ASIASAT 3 KU BAND
    2. NSS 6 KU BAND
    3. YAMAL 201
    4. INSAT 2C, 3B, 4A
    5. TELSTAR
    6. PAS 7/10
    On the 2nd 8 feet dish I receive 5 satellites by fixing 5 dual LNBs
    1. ASIASAT 4
    2. ASIASAT 3
    3. ASIASAT 2
    4. INSAT 4C KU BAND
    5. ST 1 & CHINA STAR
    On 3rd 8 feet C band dish I receive YAMAL 202 and on 4th 4 feet KU band dish I receive ARABSAT 2D (EUROBIRD 2) KU BAND.
    I am sending you 2 photographs of my dish.
    Jun 2007
    Default What Type dish he is using Solid or Mesh for Yamal 201
    Sir Can you please tell me his 8 feet Dish on which he is receiving Yamal 201 at 90 degree is Solid 8 feet or Mesh dish and which Tp of yamal 201 has higher signal strength and which Lnb/Feedhorn he is using for Receiving Yamal 201
    canine consultant Expert
    Firstly, what you must consider is if your dish is "Mesh" is it in fact Ku capable.
    Then you also have to consider if you require a Universial LNB, as combined C // Ku LNB's can't cover a ku universial frequancies, all KU LNB's on a combined unit are standard 11300 LNB's .
    Really nothing beats a dedecated dish. But Ird**to 2 Enginner retails a fine example of a combined unit, and cheap too..
    regards from OZ bassett
