    NWFP KOHAT PAKISTAN
    Default Help for Two RECEIVER
    dear all rdi,
    i have two kind of receiver one is starsatx550 and 2nd is astrovox 2600 fta.i have one antenna.i connect the receivers to antenna but when i change the channel the other show bad signal.
    when i watch Horizantal channels than the other receiver do not show vertical channels.help..........
    philippines
    Default Re: Help for Two RECEIVER
    Quote Originally Posted by salman2000
    dear all rdi,
    Maybe you are using only single type LNB..For the two receivers in one dish, it's better to use dual type LNB to avoid conflict.
    Quetta Pakistan
    U will have to use Dual Pin LNB
    and Disconnect ur Current System as soon as possible other wise u will lost any of thing.
    yeah, a twin output lnb is in order here. or you can use a multiswitch disecq, which is more expensive.
  1. Help me to buy Receiver
    By nauman1 in forum RDI - English
    Last Post: 12th July 2006, 06:06
  2. NEW RECEIVER
    By b2rster in forum RDI - English
    Last Post: 12th June 2006, 00:15
  3. which receiver is best
    By dillberz in forum RDI - English
    Last Post: 17th April 2006, 12:07
  4. 1 receiver ---<>>>>2 LNB
    By niku_1988 in forum RDI - Satelit
    Last Post: 25th June 2005, 23:32
