Results 1 to 15 of 17
    Jun 2007
    Default Can I Receive ABS1 or ST1 on my 90 CM KU+C combine Dish
    HI,
    I have a combo C+ Ku combine Dish I receive Asiasat & nss6 on that Can I receive C band from ABS1 or ST1 on that Antenna.
    East Malaysia
    Smile C & Ku
    Dear Friend ,Your detail is not clear ,as for what ch and what is your location? You have to confirmed your location and the range the signals are falling at your place,if you have got that confirmed than you can refer it with Lyngsat.com
    HI,
    Jun 2007
    Hi Friend,
    After Refering to site Footprint for C band in Bangalore is 41 DB Still I am unable to receive on my 90 CM Antenna I want to catch ST1 3418 H 8333-5/6.
    and Ku Band K2 beam is 52 DB still I am unable to receive 11693 H 12000 TV Lanka Channel 1.
    Yesterday It was a cloudy day does clouds make the Signal weak.
    Chennai, India
    Hi Friend,
    Clouds will make signal weak in Ku band but it will be worse only if it is raining. First try Pol:V on St1 for C band. I am not sure whether you will get it or not. But TV Lanka should be getable.
    Apr 2007
    Hi Friend,
    I have a 90 cms C+Ku band combo dish from MCBS. Though I donot use the C-Band Part But I use the KU LNB to point to ABS-1/Edusat. Getting ST1 is absolutely no problem. You will get around 80% signel just by roughly tuning it. Its got a very strong beam. It was the first sat I could receive.
    A small tip you could use: Never tune your dish on a cloudy/rainy day. Try tuning on a bright morining around the time frame 7:30 AM to 10:00 AM. 8:30 to 9:00 AM is the best time to receive and tune KU band signals. This is my experience!
    Mangalore
    Jun 2007
    Quote Originally Posted by Mangalore View Post
    Mangalore
    Thanks Mangalore friend which Satellites r u able to receive with ur 90 CM Dish.
    Coimbatore India.
    Default ABS1 and ST1
    Hi Friend,
    Hello Friend,
    I am in coimbatore and 3418 H in ST1 and 11693 H 12000 TV Lanka Channel 1 are receivable. pls adjust for max signal gain from other sat and try this sat.
    alanpaladka
    I think ST1 can be receivable. But I doubt on ABS reception.
    @Mangalore @Bangalore
    Nice combination. Major cities of Karnataka.
    Chennai, India
    @alanpaladka
    You are also from Mangalore? Still Mysore is missing
    Keep us updated about receiving C band on 90cms dish. All the best
    Jun 2007
    @alanpaladka
    Thanks Brother
    Jun 2007
    Default Brother can anyone tell me about C+KU band combine LNBF is it available in Chennai
    Brother can anyone tell me about C+KU band combine LNBF is it available in Chennai if Yes what will be the price of that
    Chennai, India
    I already posted it brother. Ok now again telling. It depends. They some times sell for Rs.1400 and some times Rs.1800.
    Apr 2007
    Let me be very clear, I donot use my 90 Cms for C-Band. Only KU-Band.
    @Allan
    Well I am currently receiving ABS-1/Edusat KU from my 90 cms dish, I can assure you that. I live in Surathkal , Mangalore.
    While i was tuning for ABS-1 and edusat, i was trying other sats such as EuroBird-2, Intelsat 12, NSS11 (Just 1 encrypted channel) and ST1. I can confirm I have received all these. In addition to these I have received the obvious NSS6 and In4b KU.
    But I have tried for C-Band, I have received the regional TP's of Thaicom 5. I couldnot receive the Global TP's, This was in May. During the rains I have Just fixed my dish to ABS-1 KU band.
    I have removed my C-Band LNB and Tucked it safe inside my draw! I will start experimenting once the rains subside!
    Anyways. I hope this is useful!
    Mangalore
    Feb 2007
    I am have 60cm dish can i receive st1 and other sats?
    Jun 2007
    Quote Originally Posted by sharma View Post
    Mr Sharma tell me ur location
