Results 1 to 15 of 15
Thread: help 93*E
    Nov 2005
    sialkot
    Default help 93*E
    can i watch in sat 3a.4b 93*E in sialkot i have 2 feet KU dish?
    skystar2,pas10/7,asia sat3
    0821099849311
    21.95° N 97.06° E
    Quote Originally Posted by shehbaz View Post
    First u should tell us ur location and then friends will tell u what size of dish u need to catch this bird.
    Regards.
    " 李俊明 Born To Help People "
    Chennai, India
    Regards.
    His location is Sailkot
    pakistan
    look at footprints i think u can receive signal in sialkot but at least six feet dish required.anyway try ur luck.
    http://www.lyngsat-maps.com/maps/in4b_india.html
    Mar 2007
    Question
    Hello, what about in Dubai, whats the size of dish required & specification of LNB to get insat 4B package
    pls advise us.
    Africa-Kenya-Nbi
    Quote Originally Posted by THE DON View Post
    pls advise us.
    the EIRP in dbw of the area in ref. to chart tells the size of dish required, though the coverage is mostly India.
    you can refer ; www.lyngsat-maps.com/maps/in4b_india.html
    Sep 2006
    Thumbs up
    Dear,
    THE DON
    You can receive the all channels of Insat-4B (93.5' East) Satellite, at Dubai with using 2.10 meter dish anteena and any ku band lnb. strong signal transponder is 11150, vertical, 27500, 3/4 ( sun tv) and weak signal transponder is 11570, 27500, 3/4 (jaya tv)
    I am getting all channels of Insat-4B at K.S.A.
    Apr 2006
    DUBAI
    In Dubai, with 105cm dish it is possible all channels but in midnoon some disturbance. With 120cm dish no problem at all.
    Strong signal is 11570 V 27500; and the weak signal is 11490 V 27500
    Thanking you
    Mar 2007
    Angry
    Hello friends, Thanks a lot for reply, one more question whether i can use assembled 6 feet dish ( normaly used for c band) with Ku LNB.
    I am trying to get dish tv with same dish (55 db lnb), but i get only 11172 transponder. kindly suggest me.
    Jul 2006
    Insat 4B can be received in Bahrain & Dammam with 210 cm dia solid dish (satline) at more than 50% signal strength, signal is better than NSS6.
    Chennai, India
    As long it is solid it should work well in Ku band. For mesh you will loose some amount of signal in Ku.
    Apr 2006
    DUBAI
    Yes. Possible with new 6' Dish.
    Nov 2005
    sialkot
    i got insat4b
    0821099849311
    Nov 2005
    sialkot
    i got insat4b all channels and nss6 indian beam chanels . .2feet ku dish.
    signal 80% 70%
    can i receive any pakistani channels on this 2feet dish.
    if yes so wich satellite.
    0821099849311
    Chennai, India
    signal 80% 70%
    You can receive Ku band Pakistani channels if they are there. But for C band the dish would be small.
