Results 1 to 2 of 2
    Jun 2007
    Default dreambox 500s newbie problem
    hi,
    i already have 2.3 m c-band dish pointed to asiasat3 to receiver all fta channel using a cheap SPACE brand fta digital satellite receiver..with this receiver i am getting all those fta channels loud and clear..recently just for hobby i bought a dreambox 500s receiver so that i could do recordinng to my computer and lot other fun stuff..
    i have done all that was mentioned in dreambox manual..it's got default enigma image..
    i put the lnb cable to dreambox and turn it on..
    i select asiasat3 from list of satellites in menu and direct lnb to satellite setting..
    and when i do automatic transponder scan ,it doesn;t find any channels..channel doesn;t lock up..the signal quality is shown 78% in menu,but there is not tick on the trasnponder lock..
    can some one guide me what i am missing here..i have got this lnb.
    http://www.mti.com.tw/images/Product...-2C%20Spec.pdf
    when i use my space receiver i get all channels..i want to receive same channels with dreambox too..
    thanks
    Ram
    Check you LNB settings in DM.You need to use Non Standard user defined configuration.Enter 5150 in H,L & Treshold
