    Jun 2007
    Exclamation Thaicom 5 problem
    Hi Guys. I got some problem with Thaicom 5.
    3475 V 12800 3/4
    3585 V 26666 3/4
    Both of the above transponders of the Thaicom 5 are in the same beam (Regional). But I can't get the 1st transponder although I can get the second one very clearly (Strenght 69% & Quality 74%)
    I'm from Sri Lanka. Please help
    Africa-Kenya-Nbi
    Quote Originally Posted by dimu1234 View Post
    3475 V 12800 3/4
    3585 V 26666 3/4
    At times you get frequency allocations without transmision. so you can get the signal but no quality or BER or lock.
    Maybe you can consult anyone you know is on same beam. and some transmissions switch off at certain times, bear that in mind too.
    Chennai, India
    It also depends on the uplinking station's signal strength. First make sure they are transmitting by verifying this with a friend. Most probably they aren't.
    3475 V 12800 3/4
    3585 V 26666 3/4
    just add 1 or 2 mhz or reduce 1 or 2 mhz-actually the first tp is very strong than the second tp.
