    Jun 2007
    Default dreambox 500s problem help
    hi,
    i just received a dreambox 500s from china manufacturer..
    when i plugin to my tv,i get the menu sometimes only...rest of the time just blank screen....the green light is always on...and seems the dreambox shuts down and start every few seconds...when i connect dreambox to my adsl router,the ethernet network green light keep flashing every 10 seconds,the network card in dreambox light is on and off every seconds...i can';t seem to connect it to the LAN..i have default enigma image...
    do u guys have faced smiliar problem...what's the way to fix this..]also the light in audio digital at the back of dremabox is on and off every 5 seconds....
    thanks
    Ram
    canine consultant Expert
    Quote Originally Posted by ramsharan View Post
    hi,
    thanks
    Ram
    Send it back..
    regards from OZ bassett
    THAILAND
    Send it back..
    A few years ago tried to send a defective receiver back to the China manufacturer and discoved you can't. The import of sat receivers into China was/is prohibited !
    Solution ? You send back the motherboard , less postage also !.
    Sep 2006
    Exclamation
    It is possibly a corrupt image , use dream-up do a flash erase and image install .
    www.sattronics.net -
    No 1 for satellite tv equipment in Australasia
    email me - [email protected]
    skype me - sattronics
    Africa-Kenya-Nbi
    Quote Originally Posted by sattronics View Post
    take this risk, should be the solution out for you.
    While setting up you have probably put in more cams
    than it can take.
    Dreamflash is a way out
