    philippines
    Default Need Help for Connecting STB to Computer?
    I have problem in downloading the firmware from computer to receiver. I am using Cable RS232(female), I followed the wiring in accordance with the wiring diagram as I have found from the websites. . I Link PC to STB with RS-232 Cable(female), but when I’m trying to download the file through the program, the “connection failed” message appeared. What should I do? How do I know if the connection in the computer is correct? Do I have to configure the setting of COM port? Thanks.
    asia
    Default Re: Need Help for Connecting STB to Computer?
    Quote Originally Posted by carlomaderazo
    looks like you are in great trubel m8. if you follow the wiring diagram base on the webbie you get from, then certainly your cable are right but did you ever check the cable resistance continuity after your wiring modification? if you did, then try to re check the COM port settings and reconfigure it ( Normally, com 1 and 2) " Connection failed" means there is no connection from PC to STB... i guess you loader is belongs to STARSAT FAMILY...
    philippines
    Quote Originally Posted by lakaypogi
    I already checked the cable continuity and all connections are OK. But I'm not sure how to do COM port settings and reconfiguration. I only click COM port 1 or 2 in the selection of the program.. Could you tell me if there is an special setting of this in the computer? I'm using EmUpgrade. Thanks.
    Byte Stalker Mentor
    Planet Earth in Universe
    m8s,
    starts from the highest speed, then go down where it works, usually the default will do whether your handshaking is hardware or software.
    by the way are you using a laptop? most new laptop does not have enough current supplied to its com port!
    Turn off the( after tuning it to any FTA channel) main switch of the STB, before running emu upgrade then switch it on when you click start.
    hope it will work, give us feedback... more info
    you can check on control panel/system/device manager/comports/properties/advanced/port settings if your comport is indeed set to com 1 or 2.
    philippines
    OK m8s, the problem solved…thanks anyway.
    But I have another query…Is this connection can possibly used in laptop computer by using USB-RS232 adaptor with the same configuration? Because all new laptop in the market does not provided serial port.
    Thanks again.
    @carlo,
    yeps, i am using a prolific usb-serial adaptor for my laptops.
  1. Recording pe computer
    By majka in forum DREAMBOX
    Last Post: 6th October 2006, 19:54
  2. connecting a plasma
    By mariust5 in forum RDI - English
    Last Post: 17th March 2006, 23:50
  3. PLZ HELP ABOUT COMPUTER DVB.......
    By shehbaz in forum RDI - English
    Last Post: 4th February 2006, 09:29
  4. computer dvb
    Last Post: 2nd December 2005, 15:22
