Results 1 to 12 of 12
    Jun 2007
    Default Polarity problem (H/V/L) difference, please experts can you advice me?
    dear friends
    I am able to receive some satellites such as asiasat/panamsat etc OK with my technosat LNB and decoder.
    Looking at the page for Yamal 202
    http://www.lyngsat.com/yamal202.html
    I notice polarity is described as L (instead of the usual V and H)
    My questions:
    1. do I need new LNB to receive this polarity as my LNB can only get V and H polarity?
    2. Do I need new STB also? My stb has only option for Vertical or Horizontal not L, can I use same STB (It is technosat 555)
    dear experts can you please advice me what I should do?
    thank you for your kind help
    Apr 2007
    Polarities L and R are circular (left or right). They can be picked up on both V and H provided the signal is strong enough and you dish is big enough.
    Sometimes the signal is slightly stronger on V then H and sometimes it's slightly stronger on H than V.
    No need for a new STB or LNB just try and scan in all the channels with that freq FEC and SR on V or H. If you can't get them on V or H you will probably need a bigger dish.
    Jun 2007
    dear dragon47
    thank you very much for your kind and helpful reply. I will try that.
    I am in Sri Lanka trying to get Yamal 202. According to footprint it is possible to get Yamal 202 easily in sri Lanka.
    Tried today was unable to locate. Will try again
    Can anyone tell me which are strongest transponders in Yamal 202? So I can try pointing dish while tuned to those? thank you all again
    dish is 6 **** solid dish
    My receiver has only option for Vertical and Horizontal under polarity. How should I set it to L? (it is a Technosat 555)
    Africa-Kenya-Nbi
    for L and H transponders use the teflon plate, fit it in the C band lnb
    then the circular waves can be received as V and H.
    mostly if your dish is not very big, you need the plate.
    Dstv HD PVR
    Jun 2007
    Asante Sana, Cogil. Seeing the flag in your sig brings back fond memories.
    Actually, you guys are lucky in africa as you get excellent satellite coverage and access to satellites like Arabsat and Hotbird which are hard/impossible to receive on this side of the world. The one problem you have is paid satellite TV e.g. multivision is hellishly expensive vs over here where you can get all the channels you want for about $10 - $20.
    Re: teflon plate - I don't seem to have one. Is it possible for me to construct something and use? I have a very simple C band LNB from technosat, opening the lids I just saw a cylinder with two spikes inside I think.
    Do you have any suggestions as to how I could construct one - if not possible I guess I will try to buy another LNB
    Just two questions if you don't mind me asking:
    1. Does REN TV contain any english programming? The web site shows many modern series channels
    2. Assuming I get another LNB/teflon plate, do I need to get a new decoder? Mine only has options for Horizontal and Vertical polarity. Or, does the existing decoder do the job with H and V being equivalent for L and R?
    Jun 2005
    Australia
    Hi lank22,
    You can try to make a plate out of an old choppingboard.
    The white skinny plastic (teflon) ones are ideal for this purpose.
    Another thing you can try is to make a wave guide by using a soda can (or similar) that has the bottom cut out and two sides flattened out (so the tunnel will look more oval than round), Fit this over the front of the LNB.
    Good luck.
    Oct 2002
    United Kingdom
    i think you meen for L and R transponders use the teflon plate
    ABA
    Jun 2007
    H lank22, I'm also from Sri Lanka. I'm receiving Yamal 202 (49 E) wit my 6 feet solid dish. What you have to do to get it is to put the little teflon plate (you get with your C band LNB) inside your LNB. In my LNB it's marked the place where I have to place the teflon plate. After that I get the L & R transponders in my normal STB. (I get all the channels in the Yamal 202 as V pol.
    Only 10 FTA channels available in Yamal 202 including TVLanka 1 & 2.
    Quote Originally Posted by lank22 View Post
    dear friends
    My questions:
    plz visit this thread for more help.....
    Africa-Kenya-Nbi
    "Asante pia Lank22" and thanks on the fond memories.
    I see your questions have been answered, you dont need another decoder, and anybody on sats will give you his teflon plate free, if not using.
    Plus the eurostar lnbs - cband come with it, alo geomax.
    By the way we dont get Hotbird. Any further querries welcome.
    Africa-Kenya-Nbi
    Quote Originally Posted by ABA View Post
    Thanks ABA you are right i meant L and R
    Africa-Kenya-Nbi
    you can also go through this old topicL AND R
