    Nov 2006
    Default c ku problem on diseq switch
    hi friends
    i am using a 4 way disecq switch on my dvb card using my thetre and dvb dream , previously i was using two lnbs both of ku band , 1 on hotbird and 1 on nss6. now i removed nss6 and pointed my dish on asiasat, everything is the same but the problem is none of dvb programe scans c band channels on asiasat , but it scan cband when i remove diseq switch .
    whats the problem is ithsi switch is not compatible with cband , when ever i scaneed asiasat it gave me the hotbird channels using some frequency 3740 v , ist it amazing.
    hope some one help me to sort it out.
    thanks
    Chennai, India
    Did you give the correct Diseqc port in the DVB card software? if yes then switch might be faulty. Try on the other ports (1,2,3,4).
    South India
    Quote Originally Posted by pinkgypsy View Post
    hi friends
    thanks
    another important thing is to select the LNB type? is it selected Cband?
    You cannot teach a man anything; you can only help him find it within himself.
    Nov 2006
    Need transponders ini files...! Updated One. This days joshyfun.peque.org is not updating.Iinstantly.
    az30094
    hi friends
    thanks
    This type of problem I am also facing. I use a SS2 card with altdvb (my favourite program). Changing channels across different satellites that are connected to different ports of diseq switch sometimes fails to switch to the new port. In this case, scanning the satellite gives the results from the previous satellite.
    I also use a stand alone receiver. Here, the same setup, but changing channels does not pose any problems.
    My conclusion - the SS2 card is not doing a good job of sending the right voltage (or fails to supply the required current) to the diseq switch for switching the ports.
    If you have a stand alone receiver, try and share your results.
    Nov 2006
    yes dear az u r very much right standalone reciever is working fine for me and i think problem is this dvb card i s not switching ports bcoz when i only insert cband lnb it scan all the channels without any problem . transponder files not a problem as i already updated asiasat3.
    thanks
    THAILAND
    A FAR BIGGER PROBLEM IS TRYING TO USE DISECQ WITH A 22 KH SWITCH. MOST SWITCHES....ALL THOSE I TESTED...WILL NOT LET THE DISEQC TONE THROUGH SOMTIMES SAME PROBLEM USING A 0/12v SWITCH .
    Chennai, India
    thanks
    My receiver too some times refuses to switch.
