Results 1 to 10 of 10
    Jan 2007
    Default please help for NSS 6 chanals
    Hi friends
    Last Many days I have no recived NSS 6 satelite chanals so what is a probleme Please help me .
    Nov 2006
    Lalu iqbal bro, Understanding your post is critical, but is ok. What is your problem cant say until you define some more, May be lnb, dish setup or cable or stb or your TV..............!
    Jan 2007
    Quote Originally Posted by member91040 View Post
    no my friend
    In my n66 satelite have some direction change or not and i also check in lyngsat web but theare also no chanals so all chanals wheare is going please tell me .
    Nov 2006
    Oo My God, Every channel is in the place. Refer satco, Retune your direction you will find it again.
    Hindustan
    Quote Originally Posted by lalu iqbal View Post
    no my friend
    Though you have not defined your problem properly and it it difficult to find a solution for that. But what I guess is your dish may be shifted from the focus. It may be due to wind or loosely screwed.
    Plz check it.
    Technology Makes You Live
    Chennai, India
    In most cases as said by Urpradhan the dish might have moved Or there may be loose connection in the cable or may be the LNB be gone dead or the receiver might be faulty. First be sure that the dish hasn't moved.
    South India
    Hi friends
    Dear lalu..
    I think ur asking about FTA channel on Nss6 which were from DD DTH.. so now u have to add different TPs in order to get those channels as DD DTH has now shifted from Nss6 to Insat 4b .
    so add these following TPs from this weblink www.lyngsat.com/in4b.html
    Hope your problem will be solved. if still can;t then please post ur question in details..
    also move ur dish a little towards ur Right hand side and lift a little if u cant get the TP signal.
    You cannot teach a man anything; you can only help him find it within himself.
    Default Nss 6 Dish Tv
    Dear Mj786 Let me know about dish tv when it will move on insat4b do you have any idea or they still giving very week signal
    thanks
    Chennai, India
    Quote Originally Posted by 1002 View Post
    thanks
    Dish tv doesn't have any plans as of now to move out of Nss6. Only DD dth moved out of Nss6 to Insat 4B.
    South India
    thanks
    Hope you got answer from lnb's post.
    Dishtv wont shift to Insat4b, instead they r acquiring the remaining 5 TPs which DD DTH left on Nss6. We can see the channels that r added on 1 of DD's TP 12688H27500
    today NDTV Profit has been added on channel number 602 and on TP 12688 H27500.
