Page 1 of 5 123 ... LastLast
Results 1 to 15 of 61
    Jun 2007
    Default Receiving Yamal 202 at 49 degree in bangalore with 6 feet antenna
    HI Friends,
    I have a 6 feet Solid sheet antenna, can I receive Yamal 201 or 202 in bangalore.
    Union territory
    yes, u can get yamal [email protected], it is very strong signal,use teflon plate, because of circular
    bye
    take care
    Chennai, India
    HI Friends,
    Welcome to the forum. You can surely receive Yamal 202 in Bangalore with a 6 feet dish.
    Jun 2007
    I have a feedhorn which I brought from local market shopkeeper told me its used to receive Sun/Udya tv from nss 703 this feedhorn will definately receive Yamal 202 please tell me its true.
    Other wise I will take a Teflon piece...
    no dear, "sun udaya" feed horn is a "righthand circullar" feed but u need "lefthand circullar" feed horn..so ask with ur shop keeper as "etv feed horn"...its
    a "lefthand circullar feed horn" and u can receive yamal very easily with this feed.,if its not available then use teflon plate.
    regards-george
    Chennai, India
    How much it costs? Normally Cirular feed is needed for receving Sun tv & Yamal. That kind of feed is not easily available. So we use Teflon on leanier feedhorns. If you have the picture of the feedhorn then post it.
    Chennai, India
    regards-george
    Can this "Etv feed horn" be used to receive other H & V signals?
    21.95° N 97.06° E
    I think that Feedhorn can't make big difference for ur signal but as in my experience big Feedhorn can give u more signal then the little Feedhorn.
    Thanks.
    " 李俊明 Born To Help People "
    Chennai, India
    Thanks.
    Actually here we get Linear feedhorns. So when we try to receive Circular polarisations we loose a lot of signal. For that we use Teflon. That Teflon helps us so much that on some satellites we cannot receive a single tp without putting the Teflon!
    Jun 2007
    etv feed horn"...its on which Satellite .....
    etv feedhorn is saperate is it available in Indian Market
    21.95° N 97.06° E
    regards-george
    I'm just confuse between these Teflon Plate and Feed Horn.Normally I know Feedhorn is which to set the LNB and collect the signal.Plz. explain me brothers.
    Thanks.
    Thanks.
    no yan u r wrong.....if u r not use the circullar feed for the circullar polarity channels, then u cannot receive 100% signal from the both polarity-cozed both polarity signal'll clash with one feed horn,if it happened then the signl level'll be dicrease..and we must use left hand circullar for the same polarity channels even there is no righthand polarity channels from the same sat and we must use as viceversa.
    and if we use this type of feed horns for the V&H polarity channels, then both polarity signals will clash with single feed horn and lnb so the signal
    level'll be decrease.
    regards-george
    once upon a time the etv telugu was transmitting over intelsat704 and with the lefthand polarity, in that time shop keepers r selling lefthand circullar lnb as
    "etv feed horn" .if u see the inside of udaya feedhorn , u can see some metal bars in feed horn and the etvfeed horn having the same but dead against from udaya tv feed horn.(opposit side--for example"udaya feed having as "///" but etv feed having as "\\\" type of metal bars)
    regards-george
    Jun 2007
    My Sun/Udya Tv feed horn which shopkeeper has given has Metal Bars on both the Sides so according to you this is waste for receiving Yamal which is in LHCP ....
    So what should I ask the shopkeeper for ETV feedhorn?
    and please guide me shall I use Telon instead of searching for Feedhorn...
    TempBmp
    TempBmp
    just ask as "etv feed" if its not available ,plz see the following picture...
    (i am sorry i am not a expert in computer)
    http://img146.imageshack.us/img146/6...onmodelan2.jpg
    but u must fix the teflon in feed horn not directly in lnb.
    goodluck!
