Results 1 to 11 of 11
    Dec 2002
    Egypt
    Post how to work tps with dreambox 500?
    & from where i can get files of keys
    thx guys
    Administrator Expert
    localhost
    Install SBCL v1.1b on C:SBCL
    Install vplug 1.7.1.1_setup in C:SBCL/plugins
    Replace v_tps.db and tps.fns with daily update.
    Open SBCL.exe, click on « tuner »..,click on « stop » check « TCP »…Port 6002… Client IP « Ip of dreambox »… check « autostart & debug »… Press start to complete.
    Click Vplug from file menu…and check « active »
    Open Cccam.cfg… add « N: « IP of your Pc » 6002 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 »
    Verify your settings on firewall
    Restart DB and open any t*s channel
    Start SBCL and make Vplug active
    Fara computer (c:\) nu se poate?
    Jan 2003
    Ba da. Emu mgcamd 1.24.
    Dar voi nu cititi RDI. Va este lene? De ce simplu, cand se poate complicat!
    si in Dream 500 cu Gbox cum merge
    Dec 2002
    Egypt
    Thumbs up
    Quote Originally Posted by Danni_X View Post
    many thanks Danni_X
    BUZAU
    Quote Originally Posted by obywans View Post
    ..si eu sunt interesat de acest aspect....dar cu gbox doar ca emulator...
    Optibox Spider HD
    HSS-7160NA (DigiTV)
    90E - 34,5V
    Jul 2006
    blowfish me....
    Quote Originally Posted by yanq View Post
    sincer nu cred ca este posibil, deci am cifra + canal + tps intre peersi si tat mumu
    desface tps da nu desface multi-u asta e.... numa cu mgcamd cu key
    localhost
    Cu gbox merge impreuna cu cs2gbox si faci linie C
    bafta !
    Jan 2008
    please can some one explaine me hwo to work with gbox2.1b
    dreambox 500s gemini3.60
    thanks
    Jul 2006
    blowfish me....
    Quote Originally Posted by chak74 View Post
    thanks
    get peers who have tps local , or use a dual gbox-mgcamd script!
