Results 1 to 10 of 10
    Satellite Internet Expert
    Default body guard 555 help required
    dear friends,
    i installed new patch 1154 ver. in body guard 555 , and according to instructions i also activated the new patch,but tps is not open,plz help me.
    or i should install the old patch 1150 to open tps?
    how were you able to install? i used a crossover cable, loaded the file, turned-on the receiver, and i got the error message that says i have the wrong ram, etc numbers.
    Quetta Pakistan
    Hello,
    With new Upgrade file this is the Problem...........
    For TPS Factory Default Ur Receiver and Retune ur Receiver u will get Tps
    dear i did it perfectly with 1154 but no tps, only absat.(may be ur downloaded file was corrupt)
    then again i installed old verion 1150,but same, absat is open no tps and no polsat
    tell me what to do plz tell urgently, i want to open tps
    thanks
    Quetta Pakistan
    Hello,
    i just check it TPS is working
    Quote Originally Posted by SHELLEYATICD
    thanks
    thanks i did it,
    now working fine
    Quetta Pakistan
    U r welcome
    dear Khawaja sahib,
    once again thanks for ur kind info.
    tps and absat r fine , but polsat is not opening,can i put the manual keys in BG 555,how?
    nah, file is not corrupt. it does all this on ALL software versions im trying to install, on two separate receivers. congratulations on your successful update.
    Quetta Pakistan
    hello,
    Polsat is not working........
    Wait for new update......
  1. Pl......................Z some body help
    By hamikhan in forum RDI - English
    Last Post: 19th August 2006, 03:20
  2. technosat body guard 555
    By kamal.86 in forum RDI - English
    Last Post: 25th April 2006, 21:49
  3. Replies: 1
    Last Post: 26th February 2006, 16:26
  4. video guard
    By mhegsi in forum RDI - English
    Last Post: 20th November 2005, 10:16
  5. want techno sat body guard 555 software
    By scrombi in forum RDI - English
    Last Post: 26th May 2005, 13:22
