Results 1 to 10 of 10
    May 2004
    Default asifde - help me out
    Asif de:
    I am getting almost all frequencies on Yamal 201 by your method - thanks for it
    But there is a problem, I am not getting specilfically this frequency on Yamal 201 at 90E. please help me.
    3907 L 4295
    Please confirm that you are getting this frequency.
    if yes , What is the signal strength of this frequency on your receiver.
    Lahore
    To get accurate polarity for russian beam you need to insert a "biscuit" provided with 'F' C Band LNB
    Fte Max 100S
    Humax IRCI-5400z
    May 2004
    masood thanks
    asifde i am still waiting your reply. where are u?
    Default Re: asifde - help me out
    Quote Originally Posted by sheetal arian
    Asif de:
    3907 L 4295
    Yes sheetal arian I am getting this frequency. and signal quality on my dish with Supermax receiver is 48%.
    If you have Zenega receiver I have checked it for you on it and on Zenega receiver the Signal level is 52% and signal quality is 62%.
    Channel name is, ORTK-12 Ch and it gives mostly rentv programs.
    By the way sheetal arian what is your location.
    May 2004
    Thank u very much asif
    As per your guidance I kept all "L "frequencies on "V" polarity and all "R" frequencies on " H"
    Plz confirm that you get this frequency on Zenega receiver with Signal level is 52% and signal quality is 62% on "H" polarity or "V" polarity.
    Regards
    Regards
    Dear i am using Poloriser with single pin LNB on my moving dish and not using LNBF with it.
    May 2004
    asifde
    you quote
    "Dear i am using Poloriser with single pin LNB on my moving dish and not using LNBF with it"
    but please mention you keep L polarity in Zenega "horizontal " or "vertical"
    Thanks
    sheetal arian,
    When we use Poloriser then there is no effect of Ver or Hor.
    THe signals remains same with both Ver and Hor.
    In Poloriser using signals improves with Skew of the Poloriser.
    If you want to check your signal by changing the polarity then you change the position of teflon as 'X' then your LC polarity will be with Hor.
    Try it may you will get it.
    Aug 2002
    "biscuit" bro pls write here this "biscuit's" company name
    maybe gala sooper tuk tuk or other new company
    maybe you want to write here "taflon" that are use for RHC LHC pol at Arabsat Cband and Yamal c band and some other saellites.
    May 2004
    Kuwait
    satlover
    masood is right taflons r also called biscuits..
    take care.
  1. asifde ...... Help needed
    By superia4u in forum RDI - English
    Last Post: 9th August 2006, 15:00
  2. Great Job Asifde.
    By nazaks4 in forum RDI - English
    Last Post: 21st February 2006, 02:58
  3. @Asifde
    Last Post: 17th February 2006, 07:37
  4. asifde plz read
    By tariq mehmood in forum RDI - English
    Last Post: 31st December 2005, 20:13
