Results 1 to 2 of 2
    Jul 2006
    Default Selevision - dual tuner receiver
    Does anyone have any info regarding this receiver ?
    Jul 2006
    Quote Originally Posted by suji View Post
    Costs approx 1000 Dihrams/Riyals
    Digital video recorder 80 Gb, browse internet
    Cannot input keys to watch encripted channels
    Link http://www.selevision.net/
    POWER SUPPLY
    Input Voltage:
    AC 90 ~ 250 (10%), 50/60 Hz
    Type:
    Switching Mode Power Supply
    Power Consumption:
    Max. 60W (10%)
    Stand-by Power:
    Max. 10W (10%)
    DEMODULATION
    Waveform:
    QPSK
    Input Symbol Rate:
    1 ~ 45 Mbit/s
    FEC Decoder:
    Convolution Code Rate 1/2,2/3,3/4,5/6 & 7/8 with Constraint Length K=7
    TUNER & CHANNEL
    2 RF Input Connector:
    F-Type, IEC 169-24, Female
    2 RF Output Connector:
    Frequency Range:
    950 ~ 2150 MHz
    Signal Level:
    -25 ~ -65 dBM
    LNB Power & Polarization:
    Vertical: +13.5 V, Horizontal: +18 V
    Current: Max. 500 mA, overload Protection
    22 KHz Tone:
    Frequency: 22 4 KHz Amplitude: 0.6 0.2 V
    DiSEqC Control:
    Version 1.0/1.2 Compatible
    VIDEO DECODER
    Transport Stream:
    MPEG-2 ISO/IEC 13818
    Profile Level:
    MPEG-2 Main Profile @ Main Level
    Input Rate:
    Max. 15 Mbit/s
    Video Formats:
    4:3, 16:9 Letter box (Default)
    Video Output:
    CVBS (Default), RGB, S-VIDEO
    Video Resolution:
    720 x 576
    AUDIO DECODER
    Audio Decoding:
    MPEG/MusiCam Layer I & II
    Audio Mode:
    Single/Dual mono/Stereo
    CONDITIONAL ACCESS INTERFACE
    Common Interface 2 slots
    HDD STORAGE & RECORDING TIME
    80 GB
    40 Hrs in 4 Mbps bit rate
    MODEM & ETHERNET
    Modem:
    56K Voice, Data & Fax
    Ethernet:
    Ethernet 10/100 Mbps Port
    SCART
    TV SCART:
    Video Output (CVBS, RGB, S-VHS)
    Audio Output (Resolution: 20 bits DAC, Max. 2 Vrms)
    VCR SCART:
    Video Input (CVBS) Video Output: (CVBS, RGB, S-VHS) Audio
    Input/Output (Resolution: 20 bits DAC, Max. 2 Vrms)
    RCA
    Video RCA:
    1 RCA/Cinch, Video Output (CVBS)
    Audio RCA:
    1 Pairs (Left & Right) RCA/Cinch Volume and Mute Control (Resolution: 20 bits DAC, Max. 2 Vrms)
    DATA PORT
    RS-232C 9-pin D-sub
    Transfer rate 115 Kbps
    FRONT AND REAR SUMMARY
    FRONT
    Slot
    2 CI slots
    Buttons: 7 buttons
    Standby, Menu, Exit, CH+, CH-, V+, V-
    Display: 3 LED
    Standby (R), LAN (R), HDD (R)
    USB 1 Port
    (slave) Version 1.1
    REAR
    Power SocketSCART
    1 for TV, 1 for VCR
    Audio
    1 pair of RCA (Left/Right)
    Video
    1 RCA for CVBS out
    Data Port
    1 RS-232C (9-pin D-sub)
    LNB
    2 RF Input & 2 Loop through Output
    S/PDIF (OPTIC)
    (IEC 95 1, Digital audio output
    Ethernet Port Telephone
    1 Input and 1 Output (pass through)
    PHYSICAL SPECIFICATION
    Size (W x H x D)
    400mm x 65 mm x 297 mm
    Weight (Net)
    3.5 kg without HDD
    Operating Temperature
    00c ~ +450c
    Storage Temperature
    -100c ~ +700c
    ACCESSORIES
    Remote control Unit including batteries
    User and Operations manual
    Cables: Power, RCA, RF, Telephone
    Splitter Socket for Telephone pass through connection.
