    pakistan
    Default guide me 4 best DVB card
    i wana buy a dvb card i already have stb star track 2 ci ...which dvb card is best and which pc do i need for it wht is the signal quality. can i see all the code channels ? is full x available on it? can i use delta card or some cam on it?
    thanx in advance.
    Default Re: guide me 4 best DVB card
    Quote Originally Posted by s6_4ever
    if you already have this stb and software is regularly updated, why shift to pc dvb, unless of course you want to record some shows
    best is relative to experience. but so far, every forum i read, they will recommend hauphauge nexus foremost, seconded by skystar and last will be the twinhan and it's clones
    for pc specs, if you will get the hauphauge nexus, you will need only a very basic 500mHz cpu since the mpeg decoding is being done by the pc dvb itself, thus freeing your own cpu load (this also explains why nexus-s are priced considerably higher compared to other pc dvb devices) but of course, the higher the specs, and more RAM you have, the better as always. personally, i would recommend at least a pentium4 2.8 with 512mb system ram, 256mb video ram and lots of hard disk space if you want to perform recording (a 1 hour video with considerable compression takes at least 13G of hard disk space)
    can i see all the code channels?
    if you have the valid code for that channel, why not?
    there have been claims, but so far not proven. before it was working on SHLcrypt plugin and then s2emu (with few seconds gap) but then it stopped since last year.
    if you buy the dvb device with CI slot, why not?
    thanx in advance.
    welcome.
    pakistan
    Default thanks
    thanks for all your info
    well i have good pc with
    3.4 GHZ
    512 rd RAM
    120 gb HDD
    128 VGA geforce FX
    hope its work
    thanks again
    do give your comment once it works on the pc dvb thread. good luck.
  1. Plz Guide
    By zulfiqarjpj in forum RDI - English
    Last Post: 6th May 2006, 21:42
  2. guide
    By hos987 in forum RDI - English
    Last Post: 8th April 2006, 16:10
  3. TV Guide
    By Unuseroarecare in forum RDI - Satelit
    Last Post: 9th November 2005, 00:45
  4. PLZ guide ..
    By Ali4u in forum RDI - English
    Last Post: 25th June 2005, 03:40
