Results 1 to 12 of 12
    alibaba
    Default Turksat 1C problem
    to all experts,
    last night i was trying to install turksat 1C using a 120cm dish to get the NBA channel using biss encryption. Unfortunately i was not able to get the signal and the NBA channel or any Turksat 1C channels. I'm using satlook for satellite dish installation. My location is Dubai. Does any one successfully install Turksat 1C using a 120cm dish here in the middle east? Please help me..NBA championship is very neer.
    thanks in advance.
    alibaba,
    yeps, actually my friend here is also using satlook to tune the receivers. just called him up last night and i ordered a 120cm dish from him, for turksat. they were able to install several dishes already here in kuwait.
    alibaba
    boknoy,
    thanks for the reply..i will just try again using my 120 cm or else better to use a bigger one i don't know exactly if there is someone there from Dubai or UAE who successfully install this satellite. your lucky in kuwait to get this signal..i hope i can shoot the bird tonight coz its getting hot in here
    thnks once again.
    alibaba
    boknoy,
    i checked the footprint of the Turkst 1C east beam here in the Dubai, UAE. unfortunately we are outside the footprint. considering that the footprint diagram is not that accurate, still the maximum dBW (EIRP) that we can receive is less than 40 dBW and it requires more than 150 cm size of dish. actually it took me hours last night using 120cm just to get this bird and i was starting to think that my "satellite dish installation skills" is failing me. now i understand.. you are lucky in kuwait because you are inside the footprint and you can really get it using just a 120 cm dish.
    check this out for the dish size..
    http://www.mlesat.com/calculat.html
    i just ordered i 180 cm dish from my friend in the market and they will deliver it today..i will just follow the rule: the bigger the better..it keeps me motivated
    thanks again
    TFC Office - Europe (#13)
    Quote Originally Posted by alibaba
    boknoy,
    thnks once again.
    @alibaba
    If you are using manual setup through your STB, use STB with FEC (1/2, 3/4, 5/6..etc) options like Humax, Signal, etc... It will help you faster dish setup. If you are using STB with Frequency, Symbol Rate & Polarization only, chances are - your installation last for several days or weeks. If you are using clone Metabox for dish alignment, chances are you will not get green quality signal.
    If you can afford to buy motorized dish it would ease your installation.
    @alibaba,
    with 120cm dish, possible, yes, but VERY difficult. so i just told my friend to bring me a 5.5ft dish (170cm) an lnb and some wires. still awaiting delivery after lunch or sometime this evening.
    @guru,
    nice tip, it really helps a lot if you can manually set your tuner to the exact settings like the SR, etc. but it won't help if you are not getting the signal in the first place. been looking for motorized accessories here in kuwait, the only thing i found is a east-west motor, (good only for directional movements, such as a yagi antenna, not inclination and lnb/dish rotation).
    boknoy,
    thnks once again.
    M8,
    Sorry I didn't notice your location is out of footprints. You are not lucky to have NBA TV, but don't lose hope, search for other packages. Your location is in the middle of visible satellites with NBA cracked.
    h**p://www.loralskynet.com/fleet/telstar18/telstar18_ku.htm
    h**p://www.satcom.gov.tr/t2a_dogu.htm
    h**p://www.ses-astra.com/satellites/footprints.php?sat=11
    You can subscribe to Showtime package, you have the best signal then.
    h**p://www.nilesat.com.eg/nilesat_eirp_Enlarg.htm
    yeah NBA is on nilesat under showtime on ******
    hmmmm...... got my Turksat up. problem with metabox, it seems it cannot decode the BISS keys. any feedback about this?
    alibaba
    Boknoy,
    download the latest software from UCAS city. then edit the DWC in the code edit menu. get the new codes from the RDI - biss key section.
    Boknoy,
    i do have the latest Dreamsoft 1.4.3.7upd installed. input the keys correctly, BISS shows green, which means key is correct, but still scrambled.
    alibaba,
    thanks, i finally figured it out. no need to change the CAID 2600 or anything for that matter, i simply input the keys on the ODD section of DCW edit in metabox3.
  1. Turksat
    By luccio_delbuccio in forum RDI - Satelit
    Last Post: 25th November 2006, 05:11
  2. Turksat 2A 42E
    By mgrace in forum RDI - English
    Last Post: 22nd August 2006, 23:51
  3. Discovery Biss Key Problem At Turksat 42 E
    By Mathila in forum RDI - English
    Last Post: 16th March 2006, 03:03
  4. turksat 42 e
    By radu80 in forum RDI - Satelit
    Last Post: 31st October 2005, 11:22
  5. TV8 - Turksat
    By sfantul_Porcarie in forum Sport
    Last Post: 22nd March 2005, 12:24
