Results 1 to 3 of 3
    Apr 2006
    Default Viasat card problem WARNING, both cws changed
    Viasat card problem on Newcs 1.20.
    ECM work, but no video. What problem?
    [mg0] WARNING, both cws changed !
    307 msec -- Sun May 20 13:56:13 2007
    ===== NDS ECM on CaID 0x090F, pid 0x1ba6 ======
    prov: 000000
    cw0:0 80 08 8C 14 45 D6 8F AA
    cw1:0 EB 2C 7A 91 0B C7 DD AF
    [mg0] -> ECM to newcamd 127.0.0.1:10001
    [mg0] <- CW from newcamd 127.0.0.1:10001 (311ms)
    311 msec -- Sun May 20 13:56:23 2007
    prov: 000000
    cw0:0 70 98 81 89 14 AD 62 23
    cw1:0 12 EB F5 F2 2E 57 6D F2
    [newcamd] EMM-G -> 127.0.0.1:10001
    [newcamd] EMM answer from 127.0.0.1:10001, 3:82
    [mg0] <- CW from newcamd 127.0.0.1:10001 (314ms)
    314 msec -- Sun May 20 13:56:34 2007
    prov: 000000
    cw0:0 DB 04 FF DE FC 2B 8D B4
    cw1:0 4F 4E D6 73 07 16 A3 C0
    Quote Originally Posted by Proximator View Post
    prov: 000000
    prov: 000000
    prov: 000000
    You are showing a local area network / LAN or local box connection to /sc01 right ~ being 127.0.0.1 the local / same box with the card in it, but at 311ms and more this can only be dialup or on a very sick DM box.
    Please tell use more information to really help you please as in a local box as you show above the connection time is less then 1ms not up to 314ms.
    If you look there will be no EMM update as well right?
    Apr 2006
    Newcs as server. mgcamd as client.
    1 year wor ok, but last 2 day get a problem.
    All client who use my card have same problem on any EMU.
    log is local box.
