Results 1 to 11 of 11
    THAILAND
    Default Better Cables Really Do Work !!
    I took everyone's advice on RDI and bought a high quality shielded cable yesterday to connect up the ultra sensitive Dream box to my tv's and also to my switching boxes and to my amazement all the feint criss cross and moving line interference patterns on the screen all disappeared !
    A tip ....these cables cost three to ten times the price of normal av cables so use only as video leads splitting the cable into three so you can use with three boxes/connections.
    Also cheaper to buy 'composite video' cables as these are much better value than the high quality German av leads and serve the same purpose .
    A big thanks to all those RDI'ers who posted the advice.
    21.95° N 97.06° E
    Thanks.That's why RDI is on the TOP and thanks to all friends for ur precious contributions here.We all appreciate ur efforts.
    Best Wishes.
    Yan Naing.
    " 李俊明 Born To Help People "
    hopefully MonsterCable won't make a hole in your pocket, lol.
    canine consultant Expert
    There's a sucker born every minute, Do you really want to get into a debate on cables and interconnects. If you think your interconnect is wonderfull, could I suggest you buy a Hi-end power lead. Also suspension towers to stop your cables dragging on the floor, or perhaps an isolation platform, together with a Power supply conditioner, and stableiser. the list goes on and on for the gullable.
    regards from OZ bassett
    Here you go, M8. might as well do the job properly,
    http://www.highendpalace.com/HEP%20Cables.htm
    THAILAND
    IT REALLY DID WORK !
    CONNECTION FROM DM BOX TO TV ....WITH ORDINARY CABLE I GOT FEINT CRISS CROSS PATTERNS AND MOVING LINES ON THE SCREEN.
    REPLACED WITH SHIELDED CABLE ...ALL LINES / INTERFERENCE GONE !
    VOILA
    VOILA
    Now make up a lead with a length of el-cheapo coax, and be amased with the differance.
    So after all the who-har, what was the make of your wonder cable.
    And there really is no need to shout, My large sensitive ears, are still flapping from the last onslaught.
    And for the record genuine Dreambox Tuners are not that sensitive. But unlike the clones of the same name, the latest dreams come with plug and play tuners, satellite, cable or terrestial.
    But to get back to the "nuts and bolts'' of your proclamation, with regard to the connections your NOW using.. Are you saying that now your using a 'composite' connection and before you where using a 'componant' or RCA or even just an RF connection. In which case, of course the picture quality will be improved.
    This is a commen ploy, that people like "monster'' cables have used for years, They hook up a TV with there over priced flash cable, [and just a small point, in the Hi-end world, monster would not make entry level] to a composite connection, and the old $2 special el-cheapo cable to the componant or RCS connection, and proclaim how wonderfull
    there super cable is, compaired with the $2 junk. But just ask them to reverse the cables and watch them back-off.
    Of cause the real test is a double blind test. but they won't be in that.
    even if it's cheap as long as the quality is dependable, i think that would be ok. but sometimes, buying these chinese made cables is a big risk to consider. true, cables may not be all that big a factor, but the guarantee that everything is well inside comes a lot. in my case, i burnt my active JBL sub by using a cheapo sub cable, turns out there were some bits/wires that were shorting from within the cable itself. talk about quality control! i changed it with monster and has no problems with it since. most of my cables are chinese made, even the optical i use is chinese made.
    so if you want to take the risk, go with the cheapo brands. but if you want to be on the safe side (after buying all those expensive equipments, you will scrimp on the cables?) go with known brands.
    and yes, at least two items from MC are listed on that page you posted.
    Fair go M8, two listing of used 2nd hand cables is hardly a feature page.
    1m Monster Cable Sigma XLR Interconnects .................................................. .................... $500.00
    8 feet set of Monster Cable Sigma Speaker Cables .................................................. .......... SOLD!
    But why haven't we had a reply from our good mate Mr C-band.
    Chennai, India
    Only loose connections or exteremly poor quality cables might be the reason for those 'criss cross'. I don't know whether we have to hurt our pocket that much for a cable. Medium quality is enough I think.
