    alibaba
    Default Experts..Help on original @metabox
    I have old original metabox 1 (@Metabox) and the front panel shows only "on" in the front panel display and the receiver does not initialize. please help me about this problem.
    thanks in advance..
    SATELLITE GURU Expert
    Default Re: Experts..Help on original @metabox
    Quote Originally Posted by alibaba
    thanks in advance..
    You need to reload the MTG software. You may have had a power surge or had a static discharge when plugging in your connections.
    You should first upload the MTG file which can be found at ucascity.
    You might also like to upload Dreamsoft 1.4.3.6 All which is a very stable platform.
    May 2004
    Kuwait
    I am sure friend that u have upgraded the wrong file in it.Upgrade ur receiver with the original software and it will be back again.
    take care.
    asia
    thanks in advance..
    you can find support of your stb here visit www.ucascity.com
    repatch with MTG FULL version, the file is at 2MB when extracted, or you can patch it up with the bootloader only (this solved my problem before).
    then repatch with DS 1.4.3.6all (as stated by irdeto2engineer) as it is the most stable version so far. the latest version 1.4.3.7upd does not have Seca2 on it, so you will miss out your channels using this encryption.[/b]
  1. i can data transfer Metabox 10 to e-Metabox ??
    By heinlynn in forum RDI - English
    Last Post: 18th September 2006, 15:34
  2. ALT-DVB sunetul in Original...
    By v11 in forum Placi DVB
    Last Post: 13th September 2006, 18:29
  3. Cam Conax Rev 1.0 Original!
    By vulcanescu35 in forum Shop
    Last Post: 16th July 2006, 00:51
  4. Original TPS Card
    By stefen in forum RDI - English
    Last Post: 14th July 2006, 06:06
  5. original metabox 1 with biss
    By alibaba in forum RDI - English
    Last Post: 31st May 2005, 16:25
