    Apr 2005
    male
    Default help arisat6000 freind
    after upgrdin this fileAR600_V3.63_20070424_1420_COMMONFILE recever front panel is black no display and not conecting wiht loader and coneting fail pls help me
    hi
    Sep 2006
    Cool Arisat-600
    Well i dont your model AR 6000, AR-600,AR-1000 and others including twin tuner, have there own loader soft, for evry model.
    You can tsek it mytechdata.com/download..
    If you put wrong software only one remedy, JTAG you can ask Yan about it..
    Africa-Kenya-Nbi
    When you try to download software to it the front panel will display "r" only,
    if that happens when connected to comp or receiver to receiver, then load back the old software, if you saved it.
    If you didn't save then get similar receiver and download the loader first then the software, it should work.
    If you can remember the old loader number, may be one can upload it for you, because you have to put old loader to light it up, then after that change loader first, then software. if all fail then go j tag, though i tried on AR600 before but j tag didn't work for me.
    Dstv HD PVR
    21.95° N 97.06° E
    @Triple_0
    Thanks Triple.
    @Sir Cogil ,
    The first method will more easier then JTag'ing as u suggest.Hope he will have the old patch in his computer.
    " 李俊明 Born To Help People "
