Results 1 to 15 of 18
    Jan 2007
    Default Need Help on Avatar
    please help for avtar .
    edit and downloading to rdi.
    Africa-Kenya-Nbi
    hi lalu,
    if the avatar is in your comp, then upload to a website, then give the url-http reference to the avatar, and will be downloaded by rdi.
    if it is on website then just give ref-www
    and it will be downloaded.
    Dstv HD PVR
    Aug 2004
    Default Hotbird
    Dear Boss
    What U Need?
    canine consultant Expert
    Click user CP, click edit Avatar, click brouse, select picture file from computer, it will need to be small [300 x 200 mm] click save changes
    regards from OZ bassett
    Africa-Kenya-Nbi
    Thanks Bassett,
    I tried it on my comp one time and couldnt work till had to upload off though a website, may be my comp was the problem, but also it was the old forum with slow speeds.
    Dstv HD PVR
    Great minds think alike, You had the web search for an avatar covered and I had the stuff we store [and can never find] on the computer covered
    Feb 2007
    Negombo, Sri Lanka
    Click user CP,click edit Avatar, click brouse, select picture file from computer, it will need to be small [300 x 200 mm] click save changes
    when you go to USER CP;
    Your Current Avatar No Avatar Specified
    Do not use an avatar
    Note: if you have a custom avatar selecting this option will delete it.
    there is only one button option which is already selected and it is
    so how can one 'upload" any?
    DM 600+80GB DM 7020+160GB+ LED 55"
    Africa-Kenya-Nbi
    Quote Originally Posted by felicianf View Post
    when you go to USER CP;there is only one button option which is already selected and it is
    try edit profile: should give you the form below;
    Your Current Profile Picture
    No Profile Picture Specified
    Profile pictures are small pictures of your self, that are displayed within your user profile.
    Custom Profile Picture
    You may upload a new custom image using the controls below.
    Option 1 - Enter the URL to the Image on Another Website
    Option 2 - Upload Image From Your Computer
    Note: The maximum size of your custom image is 100 by 100 pixels or 64.0 KB (whichever is smaller).
    Dstv HD PVR
    Feb 2007
    Negombo, Sri Lanka
    But this will not allow you to edit Avatar- It only edits the profile picture. I thinks there is something wrong in the web site. Thanks
    Africa-Kenya-Nbi
    sure felician!
    something is wrong, unless we are meant to put the avatar on the profile,
    just noticed those with avatars can access the avatar edit but not those who didnt have B4.
    will try and revert to you later on same subject.
    Dstv HD PVR
    I am not quite sure but I'm guessing a considerable amount of posts is needed in order to have an avatar. It is probably around 250 or 500.
    Africa-Kenya-Nbi
    Quote Originally Posted by SLAman View Post
    just noticed its something to do with age and posts,
    just like slaman mentions above.
    maybe ********* would tell us what is the requirement.
    Dstv HD PVR
    The way you edit the Avatar is to post another one, over the top,
    Simply click USER CP, left hand side , top, under the red word posting, then click avatar on the control panel ,left hand side
    When I joined RDI there was no avatars, this is a resent addition
    I have reached to believe that the new users (registered within this year,after the forum has changed to vBulletin) lack the second image from the editing page of the avatar.
