Results 1 to 2 of 2
    satdoctor Teacher
    Peshawar Pakistan
    Default Problem With Dish Tv..PLZ Help
    All Seniorz and friendz plz help me .. i ve got a problem of installation with Dish tv.. i have Factory reset my dish Tv STB and Now its not working..Shows a message:click ok to search channels"..when i click ok. it says :no channel found ..
    Even That menu etc all are disappeared.. Cable and signal every thing is ok..But that readymade frequencies are inserted by the company and cant be changed... WHT SHLD I DOOOOOO PLZ HELp..How shld i get all the channels back again..plz hep
    AIM
    Nov 2003
    United Arab Emirates
    Quote Originally Posted by aim_satdudez View Post
    ru using discq switch?if yes then its batter to remove it ,the problem in your stb is its home fec is not getting signal that is why it happend,go to menu the stb info then press red botton you will go to lnb setting the see the signal stranght of different fec.
    it is not a big problem you can do it.
