Results 1 to 6 of 6
    philippines
    Default Connection Cable-USB to RS232(Female)
    Hi....when we are upgrading the receiver to computer, as I know, we have to use cable RS232(both female). I would like to know, is it possible to use USB to RS232? Is it working succesfully?
    Default usb-rs232
    this is possible Have been using this type of cable to upgrade fortecstar from laptop computer no problems so far
    yeps, same thing here. using the prolific usb-serial adaptor and drivers. been using this for several months now (lappie has no serial port) on metabox, nhe, fortec, neotionbox, etc. basically all receivers willwork with it, even have an assortment of nullport cables now since i update several brands (others will require male or female cross cable, others will take only straigth pin config). it costs around 6 dollars only.
    KSA
    I have usb-rs232 cable, but it doesnt work with my laptop, i'm using win XP. driver is installed, but still not working
    Quote Originally Posted by chieboy
    what do you mean not working? try going to control panel/system/device manager/ports/ from there, edit from the advanced options the comport assignment of your usb-serial device. usually it will be assigned on comport 4, thus maybe your software is looking at comport 1 or 2, so configure it accordingly.
    KSA
    thanks, i configured the port since it is in pot 18, i changed the port to # 4, but still not working anyways i will remove the driver i try to install again.
    Thanks
  1. Need Driver for Cable RS232-USB
    By carlomaderazo in forum RDI - English
    Last Post: 30th September 2006, 07:25
  2. New Guys (RS232 Connection)
    By sahi in forum RDI - English
    Last Post: 21st September 2005, 18:45
  3. need a cable connection for superlazer
    By arif-farhat in forum RDI - English
    Last Post: 9th September 2005, 19:46
  4. Rs232 cable connection for neosat sx-1600 plus
    By immangi in forum RDI - English
    Last Post: 9th July 2005, 07:09
  5. help for rs232 cable
    By jameel in forum RDI - English
    Last Post: 2nd July 2005, 08:05
