Results 1 to 11 of 11
    Pakistan
    Default Help me to solve the problem
    HI Friends!
    When I tried to download software. I browse the software.When I click the Next button.
    A message appears"Can Not open serial Port".The process of upgrading stops.The loader and software are the same with the help of them I upgraded mySTB so many Times.
    Is this fault is in my computer or where am I wrong .Please help me in solving this problem.Thanks.
    Wattoo
    21.95° N 97.06° E
    Dear Mathila, which receiver r u try to upgrading now?
    " 李俊明 Born To Help People "
    az30094
    Quote Originally Posted by Mathila View Post
    HI Friends!
    Try switching off and on the receiver when the loader program is trying to access the serial port. Sometimes, this works.
    Check your serial port settings in the computer to see all the settings are ok. It should be, because you have upgraded your receiver many times before.
    Pakistan
    Thanks for replies.
    I have Ecolink700FTA.A day before this happen I upgraded my STB .Every thing was OK.It gives error on Com One when I select com 2 it doesw not give error but after searching it halts and does not start upgrading.
    How I can check my computer com ports please guide me.is my coputer serial port out of oder?.
    Wattoo
    Jan 2007
    Well mostly its COM1 on your computer so it must not be the problem.This happens to me everytime when i upgrade my receiver.Just try switching off your receiver and turn it on again.It works for me.If this doesnt work then then try to reconnect the serial cable and try again.
    21.95° N 97.06° E
    Thanks for replies.
    Try upgrade with another receiver and if it's still showing error then ur com port may be something wrong.Goto Device Manager and check ur port setting.Two of my computers' com ports were already dead with the shock from receiver.
    Thanks.
    az30094
    Computer getting a shock from receiver. That is interesting. Can you explain more please !
    means voltage surge. can happen in anything electronics.
    21.95° N 97.06° E
    @ az30094 ,
    The answer was already replied by Sir Boknoy.The only safer way is do not power up ur receiver before u connect RS 232 cable with ur PC and STB.
    @Sir Boknoy ,
    Thanks .
    Pakistan
    Default Help wanted
    I Tried an other receiver to upgrade.It gives error: the com port is used by an other application". so u can not upgrade.How I can find which application is using com port 1.And How I can change it. Please help me.
    Wattoo
    Banned Member Expert
    Apr 2005
    Coast of Ionian Sea
    you have probably used an application that makes your com 1 as a default port for that application. ex. i used a program like pc suite an application software for my nokia phones and i can set this software to communicate with my phones via bluetooth, infrared, or cable w/c is com 1. try to find similar programs with that same purpose. even your dial up card (modem) can be set to com 1. go to control panel is the first place you can start or directly to other softwares mentioned. hope it helps.
    No GUTS!No GLORY!
