Results 1 to 6 of 6
    Default diseq problem works 2,3 days
    i used 3 diseq and it work only 2,3 days and then out of order, even i tried on different receiever, is there anyway to make ownself a diseq ?
    az30094
    Quote Originally Posted by azamcat View Post
    Why 3 diseqs? You have more than 8 dishes? Please tell your configuration that somebody may help.
    SATELLITE GURU Expert
    What he needs is a multiswitch where you can have 8 V and 8 H polarity signals in and then say 16 out to receivers. A powered switch is best if you have long cable runs.
    Africa-Kenya-Nbi
    Quote Originally Posted by ******2engineer View Post
    wondering how your diseqs were connected to work for three days, is it from one to another, or each diseqc to one receiver.
    the best solution is the multiswitcher as above by IR2
    Dstv HD PVR
    I HAVE WRITTEN WRONG. i tried 3 time one by one on diseq switch.
    i bought 1 and it worked 2,3 days and then no work, then i bought 2nd and again 2,3 days and then no work, then i went spain and thier i used a diseqc but after 3,4 days no work. IMPORTANT: all 3 diseq switch i bought from pakistan from diferent company made. so does anyone have like this problem
    az30094
    First of all sorry for misinterpreting your post. Now it is clear.
    It is my experience that rains could cause failure of diseq switches, if they are protected properly from rain.
    Next main contributing factor is improper connection of diseq switch to multiple devices.
    If the above two sounds familiar to you, then you have identified your problem and you got the solution too. If not, then there is no other reason why your diseqs fail, especially when you have tried different brands.
