    Cebu, Philippines
    Default Pls Help Bolt-430xp
    Pls help how to change firmware of my BOLT-430XP to Nagra (DREAM) bought from China:
    Product: LLXSXTWCA_01_04 ETA
    Software: 1.8.103 build 7-23-02
    Resource: 1.24.1
    Boot: 1.6.0
    First use: 6-11-01
    VIACCESS MEDIAGUARD CONAX
    1. using rs 232 (2-3, 3-2, 5-5), front panel displays "BAD 1".
    2. Cant change parental code "invalid code always" but if you lock, 1234 or 6931 is ok.
    try to press format in your remote control for about 5 seconds and your stb will reboot then check again if the viaccess mediagurd conax is replaced by nagarvision
    Cebu, Philippines
    Default Bolt 430xp
    Thanks a lot. It is now replaced by Nagravision but everytime I switched off it returns to previous software (viaccess mediaguard conax). i have to press Format again. How can I make it permanent.
    21.95° N 97.06° E
    Quote Originally Posted by dondon View Post
    U can't do nothing about this , if u want to watch Viacces , Ir**to cards then u need to change the format.
    Thanks.
    " 李俊明 Born To Help People "
    Cebu, Philippines
    Ok thanks a lot. I only want NAGRA, can I upgrade to the latest firmware and erase VIACCESS MEDIAGUARD & CONAX?
    21.95° N 97.06° E
    No problem.u can upgrade with latest firmware but not many update software for 430.
    Thx.
    Cebu, Philippines
    Thats the problem as i cant upgrade my unit. Front panel displays "BAD1" when i connect the cable or upgrade using maestro.
