Results 1 to 2 of 2
    Default EXPERT HELP NEEDED
    Is there any method for storing channel data on pc from stb and then again loading the same frompc to stb.This is needed because during upgrading of s/ware factory reset is needed which delet all the previously stored channel and re-scaning is required again.It is simple if u are viewing only one or more fixed dishes , but in case of a motorised dish it become time tacking process to scan all the satellites one by one for motorised dish using manual positioner and locating the satellites by tracking the signals of each satellite.
    Please help to guide step by step how the channel data to be stored on pc from stb and after factory reset this data will then be transferd again to stb for Digitalllworld model SCI-190.
    Thnks
    VIRGO
    u can use setedit software from www.setedit.de (or if you can find a crack for your DAW, it's up to you.) this software will let you backup individual settings, including channel and transponder list and you can put it back after a repatch of your receiver. good luck.,
  1. to all hivion expert please help
    By newone in forum RDI - English
    Last Post: 23rd September 2006, 03:58
  2. to all expert how to put aes keys from 15 to 20
    Last Post: 16th September 2006, 06:08
  3. Need cyfra+ expert!
    By cripet in forum RDI - English
    Last Post: 25th August 2006, 07:11
  4. pleas help me all expert
    By yashpaldawani in forum RDI - English
    Last Post: 29th December 2005, 21:33
  5. technosat expert help
    By onin in forum RDI - English
    Last Post: 14th September 2005, 21:34
