    In a Weird RooM
    Default imate sound problem...
    i have a imate and its working perfect but sometimes it dosent give the sound not even receiving calls no music sounds only ringtone works of incoming calls... shud i reinstall its software if yes than how to install software in it... or it is having some other problem...?..thnx in advance,...
    Smile might be hardware issue
    Hi mate,
    This device will have 2 speakers, one for normal ear piece & another one for HANDS FREE / SPEAKER PHONE function (this also taking care of ring tones for incoming calls)
    I have used two models of imate but now i switched to O2 PDA.
    JAMES
    In a Weird RooM
    hi dude ... my problem is that its speaker stops working sometimes and after a some days or some hours it starts working again... is it some problem of imate's operating system can i reinstall the operating system..?.. or there is some technical fault..?..
    see if you have some scheduled "profiles" set on your imate.
    Byte Stalker Mentor
    Planet Earth in Universe
    could be loose contacts or coldsolder of speakers! if you have some technical knowledge in opening phones/pda try to take a peek, else have it checked in service center & also have the firmware/ software upgrade! intermittent problems are hard to diagnose!
    In a Weird RooM
    when i plug my headphones and plugout / or make the volume mute or vibration, and turn it back, i got the sound problem, i soft/hard reset device to will that it works, but not.
    then i found that if i use my headphones and want to plug out, before plugging-out i make a soft reset, and while seeing a blue screen and white I-Mate writing on it and some rom version numbers in red at bottom, i plug-out my headphones right at this time ,then i noticed that there is sound on every speaker of the device.
    That should do the solving without opening your device or sending to expensive and lazy services
    I hope it helps other I-Mate Jam users.
    i want to reinstall its windows... it is using windows mobile 2003 at the moment...
    Byte Stalker Mentor
    that's a good tip for those imate users experiencing the same as you are. what's the model of your imate m8?
    In a Weird RooM
    Quote Originally Posted by khan2ton View Post
    im havin i-mate jam here it is http://reviews.zdnet.co.uk/i/z/rv/20...am-300x400.gif
    i have no idea abt imates but i've used the Lenovo and i can say that lenovo is the best...
