Results 1 to 14 of 14
    Pakistan
    Angry Connecting 6+ LNBFs And 6+ Receivers?
    Can Some one explain that how to interconnect 6+ lnbfs and to distribute thair signal in 6+ Recievrs in a way that thay all work individuly on all LNBfs
    i think Disceq switches could not work properly in this lenthy network.
    Africa-Kenya-Nbi
    could say visit the "televes" for signal distribution amps, but still cannot figure how each receiver will work independently.
    the diseqc is on single out puts and cannot work out.
    you just have to sort out the frequencies at a point and re-distribute the signals in rf form. this is normally possible only for single providers with several channels where cards are used for descrambling, but freqs and transpoders plus polarity is same. but your case might even have more than ten transponders on different frequencies and polarities.
    maybe there is an easier way to work it out, where all the frequencies are already on and the receivers just have to tune for what is needed from the distribution amp.
    Dstv HD PVR
    Pakistan
    Post
    Dear sir Cogil
    Some compnys suply signal distribution switches could one of them
    solve this problem
    Africa-Kenya-Nbi
    Quote Originally Posted by hussain abbass View Post
    Dear sir Cogil
    solve this problem
    you should visit them and tell them exactly what you want, if they can understand their equipment well then they'll help you.some just sell but cannot practically demonstrate how to work it out
    Dstv HD PVR
    Feb 2007
    Thailand
    He needs six dual out lnbs and a 12 in 20 out multiswitch. Then each receiver can watch all the sats on all polarities.
    Easy
    Pakistan
    Exclamation
    Quote Originally Posted by Rock Spider View Post
    Easy
    Dear Rock spider
    Could u please Give more details . On the there are 5- c band lnbfs and one Ku band double output lnb
    1- Asiasat 3s 105 e v/h (single output lnbf c band)
    2- Insat 2e 3b 83 e v/h
    3- Thaicom 2/3 78 e v/h
    4- Panamsat 7/10 68 e v/h
    5- Paksat 38 e v/h
    6- Hotbird 13 e v/h (double output KU Band)
    With these dish settings there are 5 STBs in 5 different rooms of same huose
    would it be practicaly possible to make a such network with some switching device,that each Stb work properly without coflicting each other?
    Feb 2007
    Thailand
    Dear Rock spider
    5- Paksat 38 e v/h
    The swichres only care about V & H polairty they dont care about cband or ku band. So read what I wrote and change all your lnb's to dual out one coax for V one for H. But a multiswitch that has at least 6 in for C and 6 in for H and at least 6 or 10 out. Then each receiver can watch with no issues affecting another receiver
    Africa-Kenya-Nbi
    with rock spiders suggestion it is purely possible, what is not sure is whether you'll get dual output c band lnbs, you might have to get two dishes on one sat for the result of two polarities, then the multiswither as he mentioned can connect all the stbs, for any sat and polarity anytime.
    best do it practically and come out with a result.
    Dstv HD PVR
    Banned Member Expert
    Apr 2005
    Coast of Ionian Sea
    No GUTS!No GLORY!
    Africa-Kenya-Nbi
    thanks zoren, didnt know they actually exist on c band, now mr hussain can actually complete his tusk peacefully
    Dstv HD PVR
    Pakistan
    Lightbulb
    I think these are very old products . now a days the markets in pakstan are
    full with cheep chines products . availble daul polarity c band lnbfs are not working with 2 STBS working on different polarity. I will search this product in market.
    have any one idea about the price of 12 in and 6 or more out signal distributer switch?
    Africa-Kenya-Nbi
    you need not just dual polarity - this is common.
    but you need dual polarity, dual output(2 outputs)
    Dstv HD PVR
    Feb 2007
    Thailand
    You can buy a dual out Cband LNB. They have both V & H in each out and do work with 2 stb's on different polarity.
    Also if you hook them into a multiswitch you can run as many stabs as the switch has ports for.
    Pakistan
    Have u idea about the price of signal distribution switch?
