Results 1 to 15 of 16
    Default connecting a motor with supply
    recently i bought a motor and auto supply.previous i used a manual motor with pump and a motor of car with a simple supply left right.
    there is no manual that how to connect it with supply. so i doubt if i connect it wrong may be some thign will be damaged,as i bought it from rawalpindi and i live in sialkot so can not go again to ask how to connect.
    1. pls guide me, there on motor i can watch 2 screw only on motor on back side there is a plastic cover with one hole. i want to know where i will link supplies cable , on 2 screwes or on back side plastic i will remove and there will be may be some point where i have to connect cable of supply.
    2. in supply back side there are 4 points for cable and separate 2 points,
    2 points on LEFT RIGHT SIDE and 4 points for UP DOWN side. and how can er configure it with remote as there is no manual. pls guide me what should i do, thanks
    21.95° N 97.06° E
    Dear friend, can u plz. post us the picture of ur motor and then we will help u as much as we can.But not we can't tell u exactly the cable configuration and will make u damage if we r wrong.
    Mostly motor actuators have 4 pin out , two for motor and two for sensor 5+ and Gnd.
    Thanks.
    " 李俊明 Born To Help People "
    Africa-Kenya-Nbi
    for the 24 to 36 volt motors there comes a control box which is programmed just like the receiver, and is pulse controlled from receiver to box to motor.
    will post u some details if i get it
    Dstv HD PVR
    Africa-Kenya-Nbi
    This VBOX II is used to position your C band dish. It takes DiSEqC commands from your satellite receiver and converts it into 36V pulse and sensor to store positions - can store 99 Positions. It can work as a stand alone positioner or it can accept DiSEqC 1.2 commands from a satellite receiver. Motor. Controls and displays position. Remote control Included.
    Dstv HD PVR
    21.95° N 97.06° E
    I'm using both Yuri and VBoxII positioners ( I think both r clone) .And sir Cogil plz. tell me which is the best positioner and plz. explain what's the full name of DiSEqC (if it has)?
    Thanks.
    Africa-Kenya-Nbi
    Thanks.
    Hi Yan, am still waiting for my vbox after the supplier sent me the motor without the v box control, to tell u have really waited. havent seen or known yuri but you'll tell me what it is like.
    the best positioner is the vbox and the 24-36v motors for their precision, though difficult to set up, after setting works like a donkey without pay
    DiSEqC (Digital Satellite Equipment Control) pronounced "Die-Sec"
    Dstv HD PVR
    21.95° N 97.06° E
    Thanks Sir Cogil , I'll post the picture of Yuri positioner it all same with Vbox.
    Regards.
    Africa-Kenya-Nbi
    Regards.
    thanks yan will be waiting, even the site ref will do
    do u know from first post the main character of the thread azam.... has said nothing, maybe his motor is done with and running the dish, plus busy watching
    Dstv HD PVR
    21.95° N 97.06° E
    I don't know exactly what he mean , but I think he asked how to connect the cables ( don't know motor or positioner ) .
    21.95° N 97.06° E
    Africa-Kenya-Nbi
    Regards.
    thanks yan for the picture, it actually looks the same to the Vbox, maybe only different manufacturers, but same game and same work.
    Dstv HD PVR
    21.95° N 97.06° E
    Yes brother , I thnik like u too.In my region Yuri is the most popular positioner.
    mine problem solved, thanks a lot for your help, i really appreciate
    21.95° N 97.06° E
    Quote Originally Posted by azamcat View Post
    No problem brother.
    Africa-Kenya-Nbi
    what was the solution for others future reference.
    Dstv HD PVR
